HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Symbolic Reachability Analysis of Genetic Regulatory Networks using Qualitative Abstractions
Abstract : The switch-like character of gene regulation has motivated the use of hybrid, discrete-continuous models of genetic regulatory networks. While powerful techniques for the analysis, verification, and control of hybrid systems have been developed, the specificities of the biological application domain pose a number of challenges, notably the absence of quantitative information on parameter values and the size and complexity of networks of biological interest. We introduce a method for the analysis of reachability properties of genetic regulatory networks that is based on a class of discontinuous piecewise-affine (PA) differential equations well-adapted to the above constraints. More specifically, we introduce a hyperrectangular partition of the state space that forms the basis for a discrete abstraction preserving the sign of the derivatives of the state variables. The resulting discrete transition system provides a conservative approximation of the qualitative dynamics of the network and can be efficiently computed in a symbolic manner from inequality constraints on the parameters. The method has been implemented in the computer tool Genetic Network Analyzer (GNA), which has been applied to the analysis of a regulatory system whose functioning is not well-understood by biologists, the nutritional stress response in the bacterium Escherichia coli.
Complete list of metadata
Cited literature [51 references]  Display  Hide  Download
https://hal.inria.fr/inria-00133991
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Thursday, March 1, 2007 - 3:59:00 PM
Last modification on : Friday, February 4, 2022 - 3:19:45 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 12:56:10 PM
RR-6136.pdf
Identifiers
Collections
Citation
Grégory Batt, Delphine Ropers, Hidde de Jong, Michel Page, Johannes Geiselmann. Symbolic Reachability Analysis of Genetic Regulatory Networks using Qualitative Abstractions. [Research Report] RR-6136, INRIA. 2007. ⟨inria-00133991v2⟩
Share
Metrics
Record views
135
Files downloads
105
