Frame-Synchronous And Local Confidence Measures For On-The-Fly Keyword Spotting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Joseph Razik
  • Fonction : Auteur
  • PersonId : 830986
Odile Mella
Dominique Fohr
This paper presents several new confidence measures for speech recognition applications. The major advantage of these measures is that they can be evaluated with only a part of the whole sentence. Two of these measures can be computed directly within the first step of the recognition process, synchronously with the decoding engine. Such measures are useful to drive the recognition process by modifying the likelihood score or to validate recognized words in on-the-fly applications as keyword spotting task and on-line automatic speech transcription for deaf people. Two kinds of results are given. Firstly, an EER evaluation on a French broadcast news corpus shows performance close to the batch version of these measures (23.9% against 23.8% of EER). Secondly, for the keyword spotting application, our best measure provides a decrease of the false-acceptation rate by 50% with only a decrease of the correct words by 5%.
Fichier non déposé
inria-00134135 , version 1 (28-02-2007)
  • HAL Id : inria-00134135 , version 1
Joseph Razik, Odile Mella, Dominique Fohr, Jean-Paul Haton. Frame-Synchronous And Local Confidence Measures For On-The-Fly Keyword Spotting. International Symposium on Signal Processing and its Applications - ISSPA 2007, Feb 2007, Sharjah, United Arab Emirates. pp.1-4. ⟨inria-00134135⟩
119 Consultations
0 Téléchargements
