A Short Paper About Motion Safety - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Motion safety for robotic systems operating in the real world is critical (especially when their size and dynamics make them potentially harmful for themselves or their environment). Motion safety is a taken-for-granted and ill-defined notion in the Robotics literature and the primary contribution of this paper is to propose three safety criteria that helps in understanding a number of key aspects related to the motion safety issue. A number of navigation schemes used by robotic systems operating in the real-world are then evaluated with respect to these safety criteria. It is established that, in all cases, they violate one or several of them. Accordingly, motion safety, especially in the presence of moving objects, cannot be guaranteed (in the sense that these robotic systems may end up in a situation where a collision inevitably occurs later in the future). Finally, it is shown that the concept of Inevitable Collision States introduced in [Fraichard, Asama, 2004] does respect the three above-mentioned safety criteria and therefore offers a theoretical answer to the motion safety issue.
ICRA07_0326_FI.pdf (456.67 Ko) Télécharger le fichier
inria-00134467 , version 1 (02-03-2007)
  • HAL Id : inria-00134467 , version 1
Thierry Fraichard. A Short Paper About Motion Safety. IEEE Int. Conf. on Robotics and Automation, Apr 2007, Rome (IT). ⟨inria-00134467⟩
246 Consultations
861 Téléchargements
