Numerical simulation of blood flows through a porous interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a model for a medical device, called a stent, designed for the treatment of cerebral aneurysms. The stent consists of a grid, immersed in the blood flow and located at the inlet of the aneurysm. It aims at promoting a clot within the aneurysm. The blood flow is modelled by the incompressible Navier-Stokes equations and the stent by a dissipative surface term. We propose a stabilized finite element method for this model and we analyse its convergence in the case of the Stokes equations. We present numerical results for academical test cases, and on a realistic aneurysm obtained from medical imaging.
RR-6146.pdf (1.19 Mo) Télécharger le fichier
inria-00136971 , version 1 (16-03-2007)
inria-00136971 , version 2 (19-03-2007)
  • HAL Id : inria-00136971 , version 2
Miguel Angel Fernández, Jean-Frédéric Gerbeau, Vincent Martin. Numerical simulation of blood flows through a porous interface. [Research Report] RR-6146, INRIA. 2007, pp.30. ⟨inria-00136971v2⟩
179 Consultations
331 Téléchargements
