Representation and analysis of reactive behaviors: A synchronous approach, Computational Engineering in Systems Applications, pp.19-29, 1996. ,
Synchronization and Linearity: an algebra for discrete event systems, 1992. ,
The synchronous languages 12 years later, IEEE Proceedings, pp.64-83, 2003. ,
DOI : 10.1109/JPROC.2002.805826
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.71.6645
Another Glance at Relay Stations in Latency-Insensitive Design, Electronic Notes in Theoretical Computer Science, vol.146, issue.2, pp.41-59, 2006. ,
DOI : 10.1016/j.entcs.2005.05.035
URL : http://doi.org/10.1016/j.entcs.2005.05.035
Optimal design of synchronous circuits using software pipelining techniques, ICCD'98, pp.62-67, 1998. ,
Probì eme d'ordonnancement: modélisation, complexité , algorithmes, 1988. ,
Theory of latency-insensitive design, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.20, issue.9, pp.1059-1076, 2001. ,
DOI : 10.1109/43.945302
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.16.1198
A methodology for correct-by-construction latency insensitive design, ICCAD '99: Proceedings of the 1999 IEEE/ACM international conference on Computer-aided design, pp.309-315, 1999. ,
Performance analysis and optimization of latency-insensitive systems, The Proceedings of the Design Automation Conference, pp.361-367, 2000. ,
A detailed implementation of latency insensitive protocols, Proceedings of Formal Methods for Globally Asyncronous Locally Syncronous Architectures, pp.94-103, 2003. ,
Floorplanning for throughput, ISPD '04: Proceedings of the 2004 international symposium on Physical design, pp.62-69, 2004. ,
A new approach to latency insensitive design, DAC '04: Proceedings of the 41st annual conference on Design automation, pp.576-581, 2004. ,
A minimalist source-synchronous interface, Proceedings of the 15th IEEE ASIC/SOC Conference, pp.443-447, 2002. ,
DOI : 10.1109/asic.2002.1158100
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.4271
Robust interfaces for mixed-timing systems with application to latency-insensitive protocols, Proceedings of the 38th conference on Design automation , DAC '01, pp.21-26, 2001. ,
DOI : 10.1145/378239.378256
N-synchronous kahn networks: a relaxed model of synchrony for real-time systems, POPL '06: Conference record of the 33rd ACM SIGPLAN-SIGACT symposium on Principles of programming languages, pp.180-193, 2006. ,
Marked directed graphs, Journal of Computer and System Sciences, vol.5, issue.5, pp.511-523, 1971. ,
DOI : 10.1016/S0022-0000(71)80013-2
Experimental analysis of the fastest optimum cycle ratio and mean algorithms, ACM Transactions on Design Automation of Electronic Systems, vol.9, issue.4, pp.385-418, 2004. ,
DOI : 10.1145/1027084.1027085
A polynomial time method for optimal software pipelining, CONPAR '92/ VAPP V: Proceedings of the Second Joint International Conference on Vector and Parallel Processing, pp.613-624, 1992. ,
DOI : 10.1007/3-540-55895-0_462
Analysis of Asynchronous Concurrent Systems by Timed Petri Nets, 1973. ,
High-level modeling and design of asynchronous interface logic, IEEE Design & Test of Computers, vol.12, issue.1, pp.32-40, 1995. ,
DOI : 10.1109/54.350688
route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, 2004. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
