Modeling and simulation of a reformate supplied PEM fuel cell stack, application to fault detection
Abstract : A method to reduce the model of a nonlinear dynamic fuel cell stack, which is suitable for control and fault detection studies, is presented. In order to model the fuel cell stack, we have assumed that the fuel cells are arranged in a stack, electrically in series, with thermal and electrical contacts. Since in practical applications a stack may be composed of several (at least fifty) fuel cells, such model will be a large set of differential equations which may be difficult to simulate especially in control applications. In this paper, first, a model for an isolated fuel cell will be given. Then, a model for the temperature distribution in a fuel cell stack will be pursued. Finally, the use of an orthogonal collocation method to reduce the size of the model of the fuel cell stack without changing the model transient or steady state characteristics will be presented.
Type de document :
Autre publication
2007
Liste complète des métadonnées
Littérature citée [7 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00137921
Contributeur : Masoud Najafi <>
Soumis le : dimanche 25 mars 2007 - 00:34:55
Dernière modification le : vendredi 25 mai 2018 - 12:02:04
Document(s) archivé(s) le : vendredi 21 septembre 2012 - 13:10:17
Fichier
Najafi3.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00137921, version 1
Collections
Citation
Masoud Najafi, Damiano Dipenta, Karim Bencherif, Michel Sorine. Modeling and simulation of a reformate supplied PEM fuel cell stack, application to fault detection. 2007. 〈inria-00137921〉
Métriques
Consultations de la notice
199
Téléchargements de fichiers
354
