Directed percolation in asynchronous elementary cellular automata: a detailed study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cellular Automata Année : 2007
Nazim A. Fatès
Cellular automata are widely used to model natural systems. Classically they are run with perfect synchrony, {\em i.e.}, the local rule is applied to each cell at each time step. A possible modification of the updating scheme consists in applying the rule with a fixed probability, called the synchrony rate. For some particular rules, varying the synchrony rate continuously produces a discontinuity in the behaviour of the cellular automaton. This works aims at investigating the nature of this change of behaviour using intensive numerical simulations. We apply a two-step protocol to show that the phenomenon is a phase transition whose critical exponents are in good agreement with the predicted values of directed percolation.
Percolation.pdf (410.2 Ko) Télécharger le fichier
inria-00138051 , version 1 (23-03-2007)
inria-00138051 , version 2 (09-01-2008)
inria-00138051 , version 3 (13-02-2008)
Nazim A. Fatès. Directed percolation in asynchronous elementary cellular automata: a detailed study. Journal of Cellular Automata, 2007. ⟨inria-00138051v1⟩
435 Consultations
471 Téléchargements
