New interface
Journal articles
Original electronic design to perform epimysial and neural stimulation in paraplegia
David Guiraud 1 Thomas Stieglitz Gérard Taroni Jean-Louis Divoux
1 DEMAR - Artificial movement and gait restoration
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This paper presents an original electronic architecture to manage epimysial and neural stimulation using the same implantable device. All the muscles needed to achieve lower limb movements such as standing and walking can thus be activated. Mainly for surgical reasons, some muscles need to be stimulated through different inputs: epimysium or motor nerve. We developed an electronic solution, including the design of an application-specific integrated circuit, to meet the requirements of both types of stimulation. Five years after the successful implantation of the system, we were able to evaluate the system's performance. The patient is still using the system at home and no failure occurred during this five-year period. We conclude that the electronic design not only provides a unique investigative tool for research, but that it also can be used to restore motor function of the lower limb. This technology has an advantage over external stimulation because the patient can safely use the system at home. However, improvements such as lower power consumption, and thus greater autonomy, are needed. We further conclude that the modelling of the electrical behaviour of the electrodes is reliable and the estimated parameter values are homogeneous and consistent for the same type of electrode. Thus, the three parameters of the first-order model can be identified from an acute animal experiment and provide a means to optimise the design of the output stage of implanted stimulators.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00138151
Contributor : David Guiraud Connect in order to contact the contributor
Submitted on : Friday, March 23, 2007 - 3:06:19 PM
Last modification on : Friday, August 5, 2022 - 10:47:18 AM
Links full text
Identifiers
Collections
Citation
David Guiraud, Thomas Stieglitz, Gérard Taroni, Jean-Louis Divoux. Original electronic design to perform epimysial and neural stimulation in paraplegia. Journal of Neural Engineering, 2006, 3, pp.276-286. ⟨10.1088/1741-2560/3/4/004⟩. ⟨inria-00138151⟩
Share
Metrics
Record views
214
