A rational extension of Piegl's method for filling n-sided holes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2006
N-sided hole filling plays an important role in vertex blending. To deal with the case that the corner is surrounded by rational surfaces (i.e. NURBS surfaces), an algorithm to fill n-sided holes with "-G1 continuous NURBS patches that interpolate the given boundary curves and approximate the given cross-boundary derivatives is presented based on Piegl's method. The NURBS surfaces joining along inner or boundary curves have normal vectors that do not deviate more than the user-specified angular tolerance ". The boundaries as well as cross-boundary derivatives can all be NURBS curves. No restrictions are imposed on the number of boundary curves, and the cross-boundary derivatives can be specified independently.
inria-00139001 , version 1 (28-03-2007)
Yi-Jun Yang, Jun-Hai Yong, Hui Zhang, Jean-Claude Paul, Jia-Guang Sun. A rational extension of Piegl's method for filling n-sided holes. Computer-Aided Design, 2006, 38 (11), pp.1166-1178. ⟨10.1016/j.cad.2006.07.001⟩. ⟨inria-00139001⟩
139 Consultations
0 Téléchargements
