A simple bivalency proof that -resilient consensus requires rounds, Information Processing Letters, vol.71, issue.3-4, pp.155-178, 1999. ,
DOI : 10.1016/S0020-0190(99)00100-3
On the Impact of Fast Failure Detectors on Real-Time Fault-Tolerant Systems, Proc. 16th Symposium on Distributed Computing (DISC'02), pp.354-369, 2002. ,
DOI : 10.1007/3-540-36108-1_24
Distributed Computing, Fundamentals, Simulation and Advanced Topics, Wiley Series on Parallel and Distributed Computing, p.414, 2004. ,
-resilient asynchronous computations, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.91-100, 1993. ,
DOI : 10.1145/167088.167119
URL : https://hal.archives-ouvertes.fr/hal-00896459
Uniform consensus is harder than consensus, Journal of Algorithms, vol.51, issue.1, pp.15-37, 2004. ,
DOI : 10.1016/j.jalgor.2003.11.001
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.93.8980
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
Tight bounds for k-set agreement, Journal of the ACM, vol.47, issue.5, pp.912-943, 2000. ,
DOI : 10.1145/355483.355489
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.117.5266
Early stopping in Byzantine agreement, Journal of the ACM, vol.37, issue.4, pp.720-741, 1990. ,
DOI : 10.1145/96559.96565
A lower bound for the time to assure interactive consistency, Information Processing Letters, vol.14, issue.4, pp.183-186, 1982. ,
DOI : 10.1016/0020-0190(82)90033-3
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
Round-by-round Fault Detectors: Unifying Synchrony and Asynchrony, Proc. 17th ACM Symposium on Principles of Distributed Computing (PODC'00), A CM Press, pp.143-152, 1998. ,
DOI : 10.1145/277697.277724
From a Static Impossibility to an Adaptive L o wer Bound: The Complexity of Early Deciding Set Agreement, Proc. 37th ACM Sympo s i u m o n T h e ory of Computing, pp.714-722, 2005. ,
Wait-free synchronization, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.124-149, 1991. ,
DOI : 10.1145/114005.102808
Tight Bounds for k-Set Agreement with Limited Scope Accuracy Failure Detectors, Distributed Computing, pp.157-166, 2005. ,
Algebraic spans, Mathematical Structures in Computer Science, vol.10, issue.4, pp.549-573, 2000. ,
DOI : 10.1017/S0960129500003170
The topological structure of asynchronous computability, Journal of the ACM, vol.46, issue.6, pp.858-923, 1999. ,
DOI : 10.1145/331524.331529
A simple proof of the uniform consensus synchronous lower bound, Information Processing Letters, vol.85, issue.1, pp.47-52, 2003. ,
DOI : 10.1016/S0020-0190(02)00333-2
Byzantine Generals and Transaction Commit Protocols. Unpublished manuscript, 16 pages, 1982. ,
Distributed Algorithms, 1996. ,
Conditions on Input Vectors for Consensus Solvability in Asynchronous Distributed Systems, Journal of the ACM, vol.50, issue.6, pp.922-954, 2003. ,
The Combined Power of Conditions and Failure Detectors to Solve Asynchronous Set Agreement, Proc. 24th ACM Symposium on Principles of Distributed Computing (PODC'00), pp.179-188, 2005. ,
Synchronous Condition-Based Consensus, Distributed Computing, vol.18, issue.5, pp.325-343, 2006. ,
k-Set Agreement with Limited Accuracy Failure Detectors, Proc. 19th ACM Symposium on Principles of Distributed Computing (PODC'00), A CM Press, pp.143-152, 2000. ,
Consensus in synchronous systems: a concise guided tour, 2002 Pacific Rim International Symposium on Dependable Computing, 2002. Proceedings., pp.221-228, 2002. ,
DOI : 10.1109/PRDC.2002.1185641
Synchronous Set Agreement: a Concise Guided Tour (with open problems), Proc. 12th Int'l IEEE Paciic Rim Dependable Computing Symposium (PRDC'2006), pp.267-274, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00001158
-set agreement is impossible, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.1449-1483, 2000. ,
DOI : 10.1145/167088.167122
URL : https://hal.archives-ouvertes.fr/hal-00192526
Design and Analysis of Distributed Algorithms, Wiley Series on Parallel and Distributed Computing, 2007. ,
DOI : 10.1002/0470072644
A bivalency proof of the lower bound for uniform consensus, Information Processing Letters, vol.96, issue.5, pp.167-174, 2005. ,
DOI : 10.1016/j.ipl.2005.08.002
