Observer design for dissipative multivalued dynamical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the design of state observers for a class of systems with set-valued right-hand-sides. Two main classes of set-valued mappings are considered: maximal monotone and time-invariant; or normal cones to possibly time-varying sets (not necessarily convex). Such controlled systems can be embedded in various kinds of differential inclusions with absolutely continuous and bounded variation solutions (inclusions with maximal monotone multivalued mappings, and the perturbed Moreau's sweeping process), using a suitable state space transformation. The well-posedness properties of the observers dynamics are carefully analyzed. The stability of the observation error is proved. Then the problem of stabilization with a feedback control using the estimated state is studied in a particular case. Most of the results rely on rendering some suitable operator dissipative (or SPR in the linear case).
BB-MH.pdf (372.47 Ko) Télécharger le fichier
inria-00139576 , version 1 (02-04-2007)
inria-00139576 , version 2 (30-07-2007)
  • HAL Id : inria-00139576 , version 2
Bernard Brogliato, W.P. Maurice H. Heemels. Observer design for dissipative multivalued dynamical systems. [Research Report] 2007. ⟨inria-00139576v2⟩
179 Consultations
142 Téléchargements
