HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
An Interactive Problem Modeller and PDE Solver, Distributed on Large Scale Architectures
Abstract : This paper introduces a research project and a software environment to speed up and size up problem modeling with Partial Differential Equations (PDE). These PDE are defined from a \Mathematica interface, and are automatically solved by a devoted cellular automata program generated to be run on mainframes, clusters and Grids. Moreover, an interactive and graphic control of the cellular automata running allows to analyze the PDE model relevance. This environment improves large scale simulation usage in early stages of research projects.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00139660
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Friday, November 23, 2007 - 11:38:11 AM
Last modification on : Wednesday, February 2, 2022 - 3:59:39 PM
Long-term archiving on: : Wednesday, April 7, 2010 - 1:49:46 AM
File
dfma-paper.pdf
Identifiers
  • HAL Id : inria-00139660, version 1
Citation
Nicolas Fressengeas, Hervé Frezza-Buet, Jens Gustedt, Stéphane Vialle. An Interactive Problem Modeller and PDE Solver, Distributed on Large Scale Architectures. Third International Workshop on Distributed Frameworks for Multimedia Applications - DFMA '07, Jun 2007, Paris, France. ⟨inria-00139660⟩
Share
Metrics
Record views
362
Files downloads
185
