The Vlasov-Maxwell system with strong initial magnetic field. Part I : Guiding-center approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we study the asymptotic behavior of the Vlasov-Maxwell equations with strong magnetic field. More precisely we investigate the Cauchy problems associated to strong initial magnetic fields. We justify the convergence towards the so-called "guiding center approximation" when the dynamics is observed on a slower time scale than the plasma frequency. Our proofs rely on the modulated energy method.
Bostan1.pdf (382.72 Ko) Télécharger le fichier
inria-00139665 , version 1 (02-04-2007)
inria-00139665 , version 2 (05-04-2007)
inria-00139665 , version 3 (24-04-2007)
inria-00139665 , version 4 (20-02-2008)
  • HAL Id : inria-00139665 , version 1
Mihai Bostan. The Vlasov-Maxwell system with strong initial magnetic field. Part I : Guiding-center approximation. [Research Report] 2007. ⟨inria-00139665v1⟩
Collections
CERMICS
211 Consultations
475 Téléchargements
