The Vlasov-Poisson system with strong external magnetic field. Finite Larmor radius regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study here the finite Larmor radius regime for the Vlasov-Poisson equations with strong external magnetic field. One of the key points is to replace the particle distribution by the center distribution of the Larmor circles. The limit of these densities satisfies a transport equation, whose velocity is given by the gyro-average of the electric field.
Bostan2.pdf (319 Ko) Télécharger le fichier
inria-00139666 , version 1 (02-04-2007)
inria-00139666 , version 2 (05-04-2007)
inria-00139666 , version 3 (25-04-2007)
inria-00139666 , version 4 (18-02-2008)
inria-00139666 , version 5 (20-02-2008)
  • HAL Id : inria-00139666 , version 5
Mihai Bostan. The Vlasov-Poisson system with strong external magnetic field. Finite Larmor radius regime. [Research Report] RR-6159, INRIA. 2007, pp.35. ⟨inria-00139666v5⟩
194 Consultations
561 Téléchargements
