Constructing elliptic curves of prescribed order, Proefschrift, 2006. ,
Abstract, LMS Journal of Computation and Mathematics, vol.1514, pp.195-204, 2005. ,
DOI : 10.1017/S0004972700040831
On the coefficients of the transformation polynomials for the elliptic modular function, Mathematical Proceedings of the Cambridge Philosophical Society, vol.231, issue.275, pp.389-402, 1984. ,
DOI : 10.1017/S0305004100061697
Action of Modular Correspondences around CM Points, Lecture Notes in Computer Science, vol.2369, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
Die Klassenkörper der komplexen Multiplikation, Enzyklop. d. math. Wissenschaften , vol. I 2 Heft 10, 1958. ,
Fast evaluation of modular functions using Newton iterations and the AGM, Mathematics of Computation ,
DOI : 10.1090/S0025-5718-2011-01880-6
URL : https://hal.archives-ouvertes.fr/hal-00644845
Elliptic and modular curves over finite fields and related computational issues, Computational Perspectives on Number Theory: Proceedings of a Conference in Honor of A, Studies in Advanced Mathematics, pp.21-76, 1998. ,
library for univariate polynomials over arbitrary precision real or complex numbers, Version 0.1, http://www.lix.polytechnique.fr/Labo/Andreas The complexity of class polynomial computation via floating point approximations , HAL-INRIA 1040 and ArXiv cs, Enge/ Software.html, vol.10, 2006. ,
Comparing Invariants for Class Fields of Imaginary Quadratic Fields, SEA in genus 1: 2500 decimal digits. , Further investigations of the generalised Weber functions, pp.252-266, 2002. ,
DOI : 10.1007/3-540-45455-1_21
Constructing elliptic curves over finite fields using double eta-quotients, Modular curves of composite level, pp.555-568, 2004. ,
DOI : 10.5802/jtnb.460
URL : http://archive.numdam.org/article/JTNB_2004__16_3_555_0.pdf
mpc ? a library for multiprecision complex arithmetic with exact rounding, Version 0.4 ,
Isogeny Volcanoes and the SEA Algorithm, Lecture Notes in Computer Science, vol.2369, pp.276-291, 2002. ,
DOI : 10.1007/3-540-45455-1_23
Faster integer multiplication, Proceedings of the 39th Annual ACM Symposium on Theory of Computing ? STOC'07, pp.57-66, 2007. ,
Constructing isogenies between elliptic curves over finite fields, LMS Journal of Computation and Mathematics, vol.2, issue.2, pp.118-138, 1999. ,
Modern computer algebra, 1999. ,
gmp ? GNU multiprecision library ,
mpfr ? a library for multiple-precision floating-point computations with exact rounding ,
Evaluation of the Dedekind eta funktion, 2004. ,
Endomorphism rings of elliptic curves over finite fields, 1996. ,
Calcul du nombre de points sur une courbe elliptique dans un corps fini : aspects algorithmiques, Journal de Th??orie des Nombres de Bordeaux, vol.7, issue.1, pp.111-138, 1995. ,
DOI : 10.5802/jtnb.143
Ein Algorithmus zur Bestimmung der Punktanzahl elliptischer KurvenüberKurven¨Kurvenüber endlichen Körpern der Charakteristik größer drei, Dissertation, 1995. ,
Hyperelliptic modular curves, pp.449-462, 1974. ,
Beweis der Hermiteschen Verwandlungstafeln für die elliptischen Modulfunktionen, Journal für die reine und angewandte Mathematik, vol.72, pp.360-369, 1870. ,
Fast multiplication of large numbers, Computing, vol.150, issue.3-4, pp.281-292, 1971. ,
DOI : 10.1007/BF02242355
Isogénies entre courbes elliptiques, Comptes Rendus de l'Académie des Sciences de Paris, Série A, pp.273-238, 1971. ,
