A New Distillation Algorithm for Floating-Point Summation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2005
The summation of n floating-point numbers is ubiquitous in numerical computations. We present a new distillation algorithm for floating-point summation which is stable, efficient, and accurate. The algorithm iteratively "distills" the summands without discarding any significant digit until the partial sums cannot change the whole sum. It uses standard floating-point arithmetic and does not rely on the choice of radix or any other specific assumption. Furthermore, the error bound of our algorithm is independent of n and less than 1 ulp.
Fichier non déposé
inria-00143168 , version 1 (24-04-2007)
Jun-Hai Yong, Guo-Qin Zheng, Yong-Kang Zhu. A New Distillation Algorithm for Floating-Point Summation. SIAM Journal on Scientific Computing, 2005, 26 (6), pp.2066-2078. ⟨10.1137/030602009⟩. ⟨inria-00143168⟩
129 Consultations
0 Téléchargements
