Two-Point Step Size Gradient Methods, IMA Journal of Numerical Analysis, vol.8, issue.1, pp.141-148, 1988. ,
DOI : 10.1093/imanum/8.1.141
Hybrid Krylov Methods for Nonlinear Systems of Equations, SIAM Journal on Scientific and Statistical Computing, vol.11, issue.3, pp.450-481, 1990. ,
DOI : 10.1137/0911026
Convergence Theory of Nonlinear Newton???Krylov Algorithms, SIAM Journal on Optimization, vol.4, issue.2, pp.297-330, 1994. ,
DOI : 10.1137/0804017
A pure-compact scheme for the streamfunction formulation of Navier???Stokes equations, Journal of Computational Physics, vol.205, issue.2, pp.640-664, 2005. ,
DOI : 10.1016/j.jcp.2004.11.024
Nonlinear hybrid procedures and fixed point iterations, Numerical Functional Analysis and Optimization, vol.24, issue.5-6, pp.465-487, 1998. ,
DOI : 10.1137/0521009
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.99
An efficient scheme for solving steady incompressible Navier-Stokes equations, Journal of Computational Physics, vol.89, issue.2, pp.389-413, 1990. ,
DOI : 10.1016/0021-9991(90)90149-U
Méthodes générales pour la résolution des systèmes d'´ equations simultanées, C. R. Acad. Sci. Par, vol.25, pp.536-538, 1847. ,
Differential equations and solution of linear systems, Numerical Algorithms, vol.13, issue.2, pp.103-124, 2005. ,
DOI : 10.1007/s11075-005-1523-5
URL : https://hal.archives-ouvertes.fr/hal-00730194
Implicit and adaptive inverse preconditioned gradient methods for nonlinear problems, Applied Numerical Mathematics, vol.55, issue.1, pp.32-47, 2005. ,
DOI : 10.1016/j.apnum.2004.10.004
Approximation et méthodes itératives de résolution d'inéquations variationelles et de probì emes non linéaires, I.R.I.A., cahier 12, pp.139-244, 1974. ,
R-linear convergence of the Barzilai and Borwein gradient method, IMA Journal of Numerical Analysis, vol.22, issue.1, pp.1-10, 2002. ,
DOI : 10.1093/imanum/22.1.1
Numerical solutions of 2-D steady incompressible driven cavity flow at high Reynolds numbers, International Journal for Numerical Methods in Fluids, vol.126, issue.7, pp.747-774, 2005. ,
DOI : 10.1002/fld.953
Résolution numérique deséquationsdeséquations aux dérivées partielles, Dunod, p.350, 1994. ,
On the Barzilai-Borwein Method, pp.235-256, 2005. ,
DOI : 10.1007/0-387-24255-4_10
High-Re solutions for incompressible flow using the Navier-Stokes equations and a multigrid method, Journal of Computational Physics, vol.48, issue.3, pp.387-411, 1982. ,
DOI : 10.1016/0021-9991(82)90058-4
High-Reynolds number solutions of Navier-Stokes equations using incremental unknowns, Computer Methods in Applied Mechanics and Engineering, vol.130, issue.3-4, pp.319-335, 1996. ,
DOI : 10.1016/0045-7825(95)00923-X
Iterative Methods for Linear and Nonlinear Equations, 1995. ,
DOI : 10.1137/1.9781611970944
Nonmonotone Spectral Methods for Large-Scale Nonlinear Systems , Optimization Methods and Software, pp.583-599, 2003. ,
Spectral residual method without gradient information for solving large-scale nonlinear systems, Math. of Comp, 2004. ,
Preconditioned spectral gradient method, Numerical Algorithms, vol.30, issue.3/4, pp.241-258, 2002. ,
DOI : 10.1023/A:1020181927999
Méthodes de Galerkin non lináires en discrétisation parélémentsparéléments finis et pseudo-spectrale ,
Computational methods for fluid flows, 1983. ,
On the Barzilai and Borwein choice of steplength for the gradient method, IMA Journal of Numerical Analysis, vol.13, issue.3, pp.321-326, 1993. ,
DOI : 10.1093/imanum/13.3.321
The Barzilai and Borwein Gradient Method for the Large Scale Unconstrained Minimization Problem, SIAM Journal on Optimization, vol.7, issue.1, pp.26-33, 1997. ,
DOI : 10.1137/S1052623494266365
Numerical simulation of the regularized driven cavity flows at high Reynolds numbers, Computer Methods in Applied Mechanics and Engineering, vol.80, issue.1-3, pp.273-280, 1990. ,
DOI : 10.1016/0045-7825(90)90030-P
Hopf bifurcation of the unsteady regularized driven cavity flow, Journal of Computational Physics, vol.95, issue.1, pp.228-245, 1991. ,
DOI : 10.1016/0021-9991(91)90261-I
Etude numérique deséquationsdeséquations des Navier-Stokes en milieux multiplement connexes , en formulation vitesse-tourbillon, par une approche multidomaine Paris XI, 1989. ,
Navier Stokes equations, 1984. ,
DOI : 10.1090/chel/343
Efficient dsolvers for incompressible flows problems, Lecture Notes in Computational Science and Engineering, 1999. ,
Un schéma de semi-discrétisation en temps pour des systèmes différentiels discrétisés en espace par la méthode de Fourier, Résolution numérique deséquationsdeséquations de Navier-Stokes stationnaires par la méthode multigrille. Thése, 1987. ,
