Elementary transformation analysis for Array-OL
Array-OL is a high-level specification language dedicated to the definition of intensive signal processing applications. Several tools exist for implementing an Array-OL specification as a data parallel program. While Array-OL can be used directly, it is often convenient to be able to deduce part of the specification from a sequential version of the application. This paper proposes such an analysis and examines its feasibility and its limits.
