Trajectory Planning in a Crossroads for a Fleet of Driverless Vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In the context of Intelligent Transportation Systems based on driverless vehicles, one important issue is the passing of a crossroads. This paper presents a supervised reservation system. Extending previous works in this direction, the proposed algorithm determines trajectories and speeds for all the vehicles willing to pass the intersection. The work is separated into tasks shared between the vehicles and an infrastructure in charge of the crossroads. This paper describes the characteristics of the algorithm, as well as considerations which led to it. Simulation results are given and support the argument that this algorithm is probably suboptimal but still performs well. Finally, this work shows there is place for ameliorations and hints to further improve the algorithm are given.
2007eurocast_mehani.pdf (108.19 Ko) Télécharger le fichier
inria-00147208 , version 1 (16-05-2007)
inria-00147208 , version 2 (02-06-2007)
inria-00147208 , version 3 (05-03-2008)
  • HAL Id : inria-00147208 , version 1
Olivier Mehani, Arnaud de La Fortelle. Trajectory Planning in a Crossroads for a Fleet of Driverless Vehicles. Computer Aided Systems Theory - EUROCAST 2007, Feb 2007, Las Palmas, Spain. ⟨inria-00147208v1⟩
352 Consultations
553 Téléchargements
