2 ? Algorithme Balayage (AB) -Calcule P cm(r) pour une ressource donnée r ,
1 : k ? 1 ; sum h r ? 0 ; sum sl r ? 0 ; 2 : Extrait, s'il existe, le premierévènementpremierévènement e de L events tel que r ? a T e.tache ; 3 : ? ? e.date ; 4 : tant que e est défini faire 5 : | si e.date = ? alors /* ? vient juste de bouger : Calcule le k eme trapèze de P cm(r) */ 6 : | | st ? ?; sh ? sum h r ; d ? e.date ? ? ; eh ? sum sl r * (e.date ? ?) + sum h r ; 7 : | | si sh > C r ? eh > C r alors retourne Fail ; /* P cm(r) k dépasse Cr */ 8 : | | P cm(r) k ? (st, sh, e.date, eh) ; k ? k + 1 ; 9 : | | sum h r ? eh; ? ? e.date ,
Cumulative Scheduling with Task Intervals, Proceedings of the Joint International Conference and Symposium on Logic Programming, 1996. ,
A Classification Scheme for Project Scheduling Problems Project Scheduling Recent Models, Algorithms and Applications, pp.1-26, 1998. ,
Computing lower bounds by destructive improvement: An application to resource-constrained project scheduling, European Journal of Operational Research, vol.112, issue.2, pp.322-346, 1999. ,
DOI : 10.1016/S0377-2217(97)00442-6
Scheduling : the Notions of Hump, Compulsory Parts and their Use in Cumulative Problems, C. R. Acad. Sci. Paris, t, vol.294, pp.209-211, 1982. ,
Algorithms for propagating resource constraints in AI planning and scheduling: Existing approaches and new results, Artificial Intelligence, vol.143, issue.2, pp.151-188, 2003. ,
DOI : 10.1016/S0004-3702(02)00362-4
A hybrid MILP/CP decomposition approach for the continuous time scheduling of multipurpose batch plants, Computers & Chemical Engineering, vol.28, issue.10, pp.1921-1949, 2004. ,
DOI : 10.1016/j.compchemeng.2004.03.016
Computing the Envelope for Stepwise-Constant Resource Allocations, LNCS, vol.470, pp.139-153, 2002. ,
DOI : 10.1007/3-540-46135-3_10
Computing a lower approximation of the compulsory part of a task with varying duration and varying resource consumption, European Journal of Operational Research, vol.153, issue.1, pp.239-254, 2004. ,
DOI : 10.1016/S0377-2217(02)00756-7
URL : https://hal.archives-ouvertes.fr/hal-00442833
Computational Geometry, An introduction. Texts and Monographs in Computer Science, 1995. ,
Continuous Filling and Emptying of Storage Systems in Constraint- Based Scheduling. 8th International Workshop on Project Management and Scheduling -MPS, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01185227
Filtering while Sweeping over Task Intervals, LNCS, vol.2833, pp.739-753, 2003. ,
DOI : 10.1007/978-3-540-45193-8_50
