Consistency restoration and explanations in dynamic CSPs???Application to configuration, Artificial Intelligence, vol.135, issue.1-2, pp.199-234, 2002. ,
DOI : 10.1016/S0004-3702(01)00162-X
Excluding Symmetries in Constraint-Based Search, Principles and Practice of Constraint Programming, pp.73-87, 1999. ,
DOI : 10.1007/978-3-540-48085-3_6
Expert systems for configuration at Digital: XCON and beyond, Communications of the ACM, vol.32, issue.3, pp.298-318, 1989. ,
DOI : 10.1145/62065.62067
Symmetry Definitions for Constraint Satisfaction Problems, Constraints, vol.129, issue.2-3, pp.115-137, 2006. ,
DOI : 10.1007/s10601-006-8059-8
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.377.2244
Dynamic lex constraints, Principles and Practice of. Constraint Programming -CP 2006, pp.453-467, 2006. ,
Symmetry-breaking predicates for search problems, KR'96 : Principles of Knowledge Representation and Reasoning, pp.148-159, 1996. ,
Symmetry breaking in constraint programming, 14th European Conference on Artificial Intelligence, pp.599-603, 2000. ,
Groups and Constraints: Symmetry Breaking during Search, Principles and Practice of. Constraint Programming -CP 2002 -LNCS 2470, pp.415-431, 2002. ,
DOI : 10.1007/3-540-46135-3_28
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.5858
Advances in Polytime Isomorph Elimination for Configuration, proceedings of Principles and Practice of Constraint Programming -CP 2005, pp.301-313, 2005. ,
DOI : 10.1007/11564751_24
Practically handling configuration automorphisms, proceedings of the 16th IEEE International Conference on Tools for Artificial Intelligence, 2004. ,
Constraint programming in opl [12] Z. Kiziltan and B. Hnich. Symmetry breaking in a rack configuration problem, Principles and Practice of Declarative Programming Proc. of the IJCAI'01 Workshop on Modelling and Solving Problems with Constraints, 1999. ,
Isomorphism of graphs of bounded valence can be tested in polynomial time, Journal of Computer and System Sciences, vol.25, issue.1, pp.42-49, 1982. ,
DOI : 10.1016/0022-0000(82)90009-5
A classification and constraintbased framework for configuration, AI in Engineering , Design and Manufacturing, issue.12, pp.383-397, 1998. ,
Dynamic constraint satisfaction problems, Proceedings of AAAI-90, pp.25-32, 1990. ,
Composite constraint satisfaction, Artificial Intelligence and Manufacturing Research Planning Workshop, pp.153-161, 1996. ,
Representing configuration knowledge with weight constraint rules, Proceedings of the AAAI Spring Symp. on Answer Set Programming : Towards Efficient and Scalable Knowledge, pp.195-201, 2001. ,
An overview of knowledge-based configuration, pp.111-125, 1997. ,
