A New Phase Field Model of a `Gas of Circles' for Tree Crown Extraction from Aerial Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We describe a model for tree crown extraction from aerial images, a problem of great practical importance for the forestry industry. The novelty lies in the prior model of the region occupied by tree crowns in the image, which is a phase field version of the higher-order active contour inflection point `gas of circles' model. The model combines the strengths of the inflection point model with those of the phase field framework: it removes the `phantom circles' produced by the original `gas of circles' model, while executing two orders of magnitude faster than the contour-based inflection point model. The model has many other areas of application e.g., to imagery in nanotechnology, biology, and physics.
Fichier non déposé
inria-00152401 , version 1 (06-06-2007)
  • HAL Id : inria-00152401 , version 1
Peter Horvath, Ian Jermyn. A New Phase Field Model of a `Gas of Circles' for Tree Crown Extraction from Aerial Images. Proc. International Conference on Computer Analysis of Images and Patterns (CAIP), Aug 2007, Vienna, Austria. ⟨inria-00152401⟩
65 Consultations
0 Téléchargements
