Actors : A Model of Concurrent Computation in Distributed Systems, The, 1986. ,
Jam - A Smooth Extension of Java with Mixins, Proceedings of the European Conference on Object-Oriented Programming, pp.154-178, 2000. ,
DOI : 10.1007/3-540-45102-1_8
The Apache Avalon Project ,
A Case for Message Oriented Middleware, 13th Int. Symp. on Distributed Computing (DISC), LNCS 1693, 1999. ,
DOI : 10.1007/3-540-48169-9_1
From Distributed Objects to Hierarchical Grid Components, Proceedings of the International Symposium on Distributed Objects and Applications (DOA'03), 2003. ,
DOI : 10.1007/978-3-540-39964-3_78
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.6.3011
Messaging and Queueing Using the MQI : Concepts and Analysis, Design and Development, 1995. ,
FracTalk : Fractal Components in Smalltalk, 2005. ,
Mixin-based inheritance, Proceedings of the Conference on Object-Oriented Programming : Systems, Languages and Applications (ECOOP/OOPSLA'90), volume 25 of SIGPLAN Notices, pp.303-311, 1990. ,
DOI : 10.1145/97946.97982
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.156.4510
It's the aspects. Java's Developer's Journal. www.sys-con.com/story/ ?storyid=38104&DE=1. [Carbon The Carbon Project, Carbon, 2003. ,
The Speedo Project, 2003. ,
An efficient component model for the construction of adaptive middleware A component model for building systems software, Proceedings of Middleware'01 Proceedings of the IASTED Software Engineering and Applications, 2001. ,
The CLIF Project. ObjectWeb. clif.objectweb.org. [Dowling and Cahill The K-Component architecture meta-model for self-adaptative software, Proceedings of Reflection'01, pp.81-88, 2001. ,
Jonathan : an open distributed processing environment in Java, Proceedings of Middleware'98, 1998. ,
FractNet : An implementation of the Fractal component model for, NET. In 2` eme Journée Francophone sur Développement de Logiciels par Aspects (JFDLPA'05, 2005. ,
Think : A software framework for component-based operating system kernels, Proceedings of the USENIX Annual Technical Conference, pp.73-86, 2002. ,
The Hivemind Project Java Data Objects Sun Microsystems. java.sun.com/products JORAM. ObjectWeb, http ://www.objectweb.org/joram A framework for dynamically configurable and reconfigurable network-based multimedia adaptations Special Issue on Real Time Media Delivery over the Internet DREAM : un canevas logicieì a composants pour la construction d'intergiciels orientés messages dynamiquement configurables, 4` eme Conférence Francophone autour des Composants Logiciels (avec CFSE- RENPAR 2005), pp.57-66, 2002. ,
DREAM, Proceedings of the 3rd workshop on Adaptive and reflective middleware -, 2005. ,
DOI : 10.1145/1028613.1028625
URL : https://hal.archives-ouvertes.fr/hal-00881539
Fractal Explorer, Microsoft Message Queuing (MSMQ), 2002. ,
The Kilim Project. kilim.objectweb.org. The PicoContainer Project, ObjectWeb, 2004. ,
ScalAgent, une plate-forme ?? composants pour applications asynchrones, Technique et Science Informatiques, 2004. ,
DOI : 10.3166/tsi.23.253-274
Vers l'exogiciel -une approche de la construction d'infrastructures logicielles radicalement configurables, Thèse de Doctorat de l'Institut National Polytechnique de Grenoble, 2005. ,
The GoTM Project, 2004. ,
A Component Model Engineered with Components and Aspects, Proceedings of the 9th International SIGSOFT Symposium on Component-Based Software Engineering (CBSE'06), volume 4063 of Lecture Notes in Computer Science, pp.139-153, 2006. ,
DOI : 10.1007/11783565_10
URL : https://hal.archives-ouvertes.fr/inria-00126350
Gryphon : An Information Flow Based Approach to Message Brokering, Proceedings of ISSRE'98, 1998. ,
FuseJ : An architectural description language for unifying aspects and components, Workshop Software-engineering Properties of Languages and Aspect Technologies (SPLAT) at AOSD'05, 2005. ,
Component Software -Beyond Object-Oriented Programming, p.pp, 2002. ,
