Wooki: a P2P Wiki-based Collaborative Writing Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stéphane Weiss
  • Fonction : Auteur
  • PersonId : 839033
Pascal Urso
  • Fonction : Auteur
  • PersonId : 830668
Pascal Molli
Wiki systems are becoming an important part of the information system of many organisations and communities. This introduce the issue of the data availability in case of failure, heavy load or off-line access. We propose to replicate wiki pages across a P2P network of Wiki engines. We address the problem of consistency of replicated wiki pages in the context of a P2P Wiki system. In this paper, we present the architecture and the underlying algorithms of the wooki system. Compared to traditional Wikis, Wooki is P2P wiki which scales, delivers better performances and allows off-line access.
RR-6226.pdf (363.71 Ko) Télécharger le fichier
inria-00156190 , version 1 (20-06-2007)
inria-00156190 , version 2 (25-06-2007)
inria-00156190 , version 3 (25-06-2007)
  • HAL Id : inria-00156190 , version 2
Stéphane Weiss, Pascal Urso, Pascal Molli. Wooki: a P2P Wiki-based Collaborative Writing Tool. [Research Report] RR-6226, 2007. ⟨inria-00156190v2⟩
Collections
INRIA-RRRT
438 Consultations
812 Téléchargements
