Multi-criteria scheduling of pipeline workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mapping workflow applications onto parallel platforms is a challenging problem, even for simple application patterns such as pipeline graphs. Several antagonist criteria should be optimized, such as throughput and latency (or a combination). In this paper, we study the complexity of the bi-criteria mapping problem for pipeline graphs on communication homogeneous platforms. In particular, we assess the complexity of the well-known chains-to-chains problem for different-speed processors, which turns out to be NP-hard. We provide several efficient polynomial bi-criteria heuristics, and their relative performance is evaluated through extensive simulations.
RR2007-32.inria.pdf (287.58 Ko) Télécharger le fichier
inria-00156732 , version 1 (27-06-2007)
inria-00156732 , version 2 (27-06-2007)
inria-00156732 , version 3 (28-06-2007)
inria-00156732 , version 4 (28-06-2007)
  • HAL Id : inria-00156732 , version 2
  • ARXIV : 0706.4009
Anne Benoit, Veronika Rehn-Sonigo, Yves Robert. Multi-criteria scheduling of pipeline workflows. [Research Report] RR-6232, 2007. ⟨inria-00156732v2⟩
Collections
INRIA-RRRT
152 Consultations
174 Téléchargements
