Chapter 2.2.4, inverse theory: problem on the line, pp.770-785, 2001. ,
Heart Rate Variability, Blood Pressure Variability, and Baroreflex Sensitivity in Overtrained Athletes, Clinical Journal of Sport Medicine, vol.16, issue.5, pp.412-417, 2006. ,
DOI : 10.1097/01.jsm.0000244610.34594.07
Proposition of an index of the autonomic nervous system activity in the arterial blood pressure short term regulation, Blood Pressure Variablity in Health and Disease, Satellite Symposium of the XVII e Scientific Meeting of the International Society of Hypertension, 1998. ,
Bound states for Schrödinger hamiltonians: phase space methods and applications, Rev. Math. Phys, vol.35, pp.504-547, 1996. ,
Effects on baroreflex sensitivity measurements when different protocols are used to induce regular changes in beat-to-beat intervals and systolic pressure, Physiological Measurement, vol.25, issue.2, pp.523-538, 2004. ,
DOI : 10.1088/0967-3334/25/2/010
Spectral Transform and Solitons, 1982. ,
DOI : 10.1007/978-3-642-82135-6_2
Inverse problems in quantum scattering theory, 1989. ,
A new impedance cardiograph device for the non-invasive evaluation of cardiac output at rest and during exercise: comparison with the "direct" Fick method, European Journal of Applied Physiology, vol.82, issue.4, pp.313-320, 2000. ,
DOI : 10.1007/s004210000226
A reduced model of pulsatile flow in an arterial compartment, Chaos, Solitons & Fractals, vol.34, issue.2, pp.594-605, 2007. ,
DOI : 10.1016/j.chaos.2006.03.096
Hemodynamic Strategies in Blood Pressure Regulation During Orthostatic Challenge in Women, Revue canadienne de physiologie appliquée, pp.351-367, 1997. ,
DOI : 10.1139/h97-023
Inverse scattering on the line, Communications on Pure and Applied Mathematics, vol.45, issue.2, pp.121-251, 1979. ,
DOI : 10.1002/cpa.3160320202
The Inverse Scattering Transformation and the Theory of Solitons, 1983. ,
Cardiovascular adjustment to somatomotor activation. The elicitation of increments in heart rate, aortic pressure and venomotor tone with the initiation of muscle contraction, Acta Physiol Scand, vol.342, pp.1-63, 1970. ,
Korteweg-de Vries equation and generalizations VI. Methods for exact solution, Communications on pure and applied mathematics, pp.97-133, 1974. ,
On the determination of a differential equation from its spectral function, Amer. Math. Soc. Transl, vol.2, issue.1, pp.253-304, 1955. ,
TRACE FORMULAS AND CONSERVATION LAWS FOR NONLINEAR EVOLUTION EQUATIONS, Reviews in Mathematical Physics, vol.06, issue.01, pp.51-95, 1994. ,
DOI : 10.1142/S0129055X94000055
Quantitative Assessment of Alterations in Regional Left Ventricular Contractility With Color-Coded Tissue Doppler Echocardiography : Comparison With Sonomicrometry and Pressure-Volume Relations, Circulation, vol.95, issue.10, pp.2423-2433, 1997. ,
DOI : 10.1161/01.CIR.95.10.2423
Doppler-derived myocardial systolic strain rate is a strong index of left ventricular contractility, Circulation, vol.105, pp.99-105, 2002. ,
Continuous stroke volume monitoring by modelling flow from non-invasive measurement of arterial pressure in humans under orthostatic stress, Clinical Science, vol.97, issue.3, pp.291-301, 1999. ,
DOI : 10.1042/cs0970291
Riesz means of bound states and semiclassical limit connected with a Lieb-Thirring conjecture II, pp.139-147, 1990. ,
Central command during exercise: parallel activation of the cardiovascular and motor systems by descending command signals, Circulation Neurobiology, and Behavior, pp.2176-232, 1982. ,
Left ventricle systolic volume in vasovagal syncope patients, Folia Morphol (Warsz), vol.62, issue.3, pp.175-178, 2003. ,
Separation of arterial pressure into a nonlinear superposition of solitary waves and a windkessel flow, To appear in Biomedical Signal Processing and Control Journal ,
DOI : 10.1016/j.bspc.2007.05.004
Sharp Lieb-Thirring inequalities in high dimensions, Acta Mathematica, vol.184, issue.1, pp.87-111, 2000. ,
DOI : 10.1007/BF02392782
Spontaneous Indices Are Inconsistent With Arterial Baroreflex Gain, Hypertension, vol.42, issue.4, pp.481-487, 2003. ,
DOI : 10.1161/01.HYP.0000091370.83602.E6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.545.9581
Altered baroreflex gain during voluntary breathing in chronic heart failure, European Journal of Heart Failure, vol.97, issue.5, pp.189-195, 2001. ,
DOI : 10.1016/S1388-9842(00)00147-1
Strum-Liouville operators and applications, 1986. ,
DOI : 10.1090/chel/373
Centrally-Generated Commands and Cardiovascular Control in Man, Clinical and Experimental Hypertension, vol.102, issue.3, pp.369-378, 1981. ,
DOI : 10.1093/cvr/11.2.87
An Exactly Solvable Model for the Interaction of Linear Waves with Korteweg--de Vries Solitons, SIAM Journal on Mathematical Analysis, vol.33, issue.2, pp.261-285, 2001. ,
DOI : 10.1137/S0036141099365431
First KdV Integrals??and Absolutely Continuous Spectrum??for 1-D Schr??dinger Operator, Communications in Mathematical Physics, vol.216, issue.1, pp.195-213, 2001. ,
DOI : 10.1007/s002200000333
Instantaneous parameter estimation in cardiovascular time series by harmonic and time-frequency analysis, IEEE Transactions on Biomedical Engineering, vol.49, issue.12, pp.1547-1556, 2002. ,
DOI : 10.1109/TBME.2002.805478
Cardiovascular autonomic control during sleep in normal subjects, European Journal of Applied Physiology, vol.87, issue.2, pp.174-181, 2002. ,
Dynamics of nonlinear blood pressure waves in large arteries, Physics Letters A, vol.194, issue.1-2, pp.77-82, 1994. ,
DOI : 10.1016/0375-9601(94)00729-9
Spontaneous Cardiac Baroreflex in Humans : Comparison With Drug-Induced Responses, Hypertension, vol.25, issue.5, pp.1058-1068, 1995. ,
DOI : 10.1161/01.HYP.25.5.1058
Baroreflex sensitivity and heredity in essential hypertension, Circulation, vol.85, issue.2, pp.497-503, 1992. ,
DOI : 10.1161/01.CIR.85.2.497
Waves Called Solitons: Concepts and Experiments, American Journal of Physics, vol.63, issue.4, 1999. ,
DOI : 10.1119/1.18083
The soliton: A new concept in applied science, Proceedings of the IEEE, vol.61, issue.10, pp.1443-1483, 1973. ,
DOI : 10.1109/PROC.1973.9296
Principles of Vascular Physiology. Panvascular Medecine. Integrated Clinical Managements, pp.116-137, 2002. ,
Contributions of msna and stroke volume to orthostatic intolerance following bed rest, Am. J. Physiol. Regul. Integr. Comp. Physiol, vol.277, pp.1084-1090, 1999. ,
Stroke volume variability and heart rate power spectrum in relation to posture changes in healthy subjects, Medical Science Monitor, vol.10, issue.2, pp.31-37, 2004. ,
The Repeatability of Left Ventricular Volume Assessment by a New Ambulatory Radionuclide Monitoring System During Head-up Tilt., Japanese Heart Journal, vol.42, issue.6, pp.749-758, 2001. ,
DOI : 10.1536/jhj.42.749
Differential effects of lower body negative pressure and upright tilt on splanchnic blood volume, AJP: Heart and Circulatory Physiology, vol.292, issue.3, pp.1420-1426, 2007. ,
DOI : 10.1152/ajpheart.01096.2006
Method and device for controlling the cuff pressure in measuring the blood pressure in a finger by means of photo-electric plethysmograph, 1985. ,
Forward and backward waves in the arterial system, Cardiovascular Research, vol.6, issue.6, pp.648-656, 1972. ,
DOI : 10.1093/cvr/6.6.648
Simultaneous measurement of stroke volume by impedance cardiography and nuclear ventriculography: Comparisons at rest and exercise, Annals of Biomedical Engineering, vol.76, issue.Suppl II, pp.475-482, 1989. ,
DOI : 10.1007/BF02368067
Solitary waves in large vessels, Journal of the Physical Society of Japan, vol.50, issue.2, pp.506-520, 1987. ,
Interaction of "Solitons" in a Collisionless Plasma and the Recurrence of Initial States, Physical Review Letters, vol.15, issue.6, pp.240-243, 1965. ,
DOI : 10.1103/PhysRevLett.15.240
