Analyse non standard du bruit, Analyse non standard du bruit, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
Analyse et représentation de signaux transitoires: applicationàapplication`applicationà la compression, au débruitage etàet`età la détection de ruptures, Actes Coll. GRETSI, 2005. ,
Closed-Loop Fault-Tolerant Control for Uncertain Nonlinear Systems, Lect. Notes Control Informat. Sci, vol.322, pp.217-233, 2005. ,
DOI : 10.1007/11529798_14
URL : https://hal.archives-ouvertes.fr/inria-00111208
Robust residual generation for linear fault diagnosis: an algebraic setting with examples, International Journal of Control, vol.34, issue.14, pp.1223-1242, 2004. ,
DOI : 10.1080/002071704200024374
Flatness and defect of non-linear systems: introductory theory and examples, International Journal of Control, vol.4, issue.6, pp.61-1327, 1995. ,
DOI : 10.1109/9.73561
Fault diagnosis in dynamic systems using analytical and knowledge-based redundancy, Automatica, vol.26, issue.3, pp.459-474, 1990. ,
DOI : 10.1016/0005-1098(90)90018-D
Robust Model-Based Fault Diagnosis for Dynamic Systems, 1999. ,
DOI : 10.1007/978-1-4615-5149-2
A geometric approach to nonlinear fault detection and isolation, IEEE Transactions on Automatic Control, vol.45, issue.6, pp.853-865, 2001. ,
DOI : 10.1109/9.928586
A flatness-based nonlinear predictive approach for crane control, IFAC Workshop on Nonlinear Model Predictive Control for Fast Systems, 2006. ,
Fault Detection and Diagnosis in Engineering Systems, 1998. ,
Process fault detection based on modeling and estimation methods???A survey, Automatica, vol.20, issue.4, pp.387-404, 1984. ,
DOI : 10.1016/0005-1098(84)90098-0
Diagnostic des syst??mes non lin??aires Contribution aux m??thodes de d??couplage, Journal Europ??en des Syst??mes Automatis??s, vol.37, issue.10, 2002. ,
DOI : 10.3166/jesa.37.1323-1327
Diagnostic des syst??mes non lin??aires Contribution aux m??thodes de d??couplage, Journal Europ??en des Syst??mes Automatis??s, vol.37, issue.10, pp.1323-1328, 2003. ,
Failure detection in linear systems, 1973. ,
An example of flatness based fault tolerant control using algebraic derivative estimation, 2006. ,
Failure detection and identification, IEEE Transactions on Automatic Control, vol.34, issue.3, pp.316-321, 1989. ,
DOI : 10.1109/9.16422
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
Analytical redundancy relations for fault detection and isolation in algebraic dynamic systems, Automatica, vol.37, issue.5, pp.687-699, 2001. ,
DOI : 10.1016/S0005-1098(01)00005-X
Control of Uncertain Systems with Bounded Inputs, Lect. Notes Control Informat. Sci, vol.227, 1997. ,
DOI : 10.1007/BFb0032160
Fault diagnosis and accommodation of a three-tank system based on analytical redundancy, ISA Transactions, vol.41, issue.3, 2002. ,
DOI : 10.1016/S0019-0578(07)60094-9
Detection filter design: Spectral theory and algorithms, IEEE Transactions on Automatic Control, vol.32, issue.7, pp.593-603, 1987. ,
DOI : 10.1109/TAC.1987.1104682
