A conservative adaptive projection method for the variable density incompressible Navier-Stokes equations, J. Comput. Phys, vol.142, issue.1, pp.1-46, 1998. ,
Mixed and hybrid finite element methods, 1991. ,
DOI : 10.1007/978-1-4612-3172-1
Eléments d'analyse pour l'´ etude de quelques modèles d'´ ecoulements de fluides visqueux incompressibles, of Mathématiques & Applications, 2006. ,
DOI : 10.1007/3-540-29819-3
Error Estimate and the Geometric Corrector for the Upwind Finite Volume Method Applied to the Linear Advection Equation, SIAM Journal on Numerical Analysis, vol.43, issue.2, pp.578-603, 2005. ,
DOI : 10.1137/040605941
A second-order projection method for variable-density flows, Journal of Computational Physics, vol.101, issue.2, pp.334-348, 1992. ,
DOI : 10.1016/0021-9991(92)90011-M
A finite volume method with efficient limiters for solving conservation laws, 1996. ,
Méthodes multi-résolution auto-adaptatives enélémentsenéléments finis : application auxéquationsauxéquations de la mécanique des fluides, 1996. ,
Numerical simulations of Low Mach models by using hybrid FV-FE methods ,
A preconditioner for generalized saddle point problems: Application to 3D stationary Navier-Stokes equations, Numerical Methods for Partial Differential Equations, vol.191, issue.6, pp.1289-1313, 2006. ,
DOI : 10.1002/num.20154
Hydrodynamic and Hydromagnetic Stability, 1981. ,
Le système de Navier-Stokes incompressible soixante dix ans après Jean Leray, Actes des Journées MathématiquesMathématiquesà la Mémoire de Jean Leray, pp.99-123, 2004. ,
Numerical solution of the Navier-Stokes equations, Mathematics of Computation, vol.22, issue.104, pp.745-762, 1968. ,
DOI : 10.1090/S0025-5718-1968-0242392-2
An explicit a priori estimate for a finite volume approximation of linear advection on non-cartesian grids, SIAM J. Numer. Anal, vol.42, issue.2, pp.484-504, 2004. ,
Lax theorem and finite volume schemes, Math. Comput, vol.73, issue.247, pp.1203-1234, 2004. ,
Third-order numerical schemes for hyperbolic problems, 1987. ,
URL : https://hal.archives-ouvertes.fr/inria-00075947
Theory and practice of finite elements, Applied Mathematical Sciences, vol.159, 2004. ,
DOI : 10.1007/978-1-4757-4355-5
Finite volume methods, VII, Handb. Numer. Anal., VII, pp.713-1020, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00346077
Approximation of variable density incompressible flows by means of finite elements and finite volumes, Communications in Numerical Methods in Engineering, vol.75, issue.12, p.893, 2001. ,
DOI : 10.1002/cnm.452
An overview of projection methods for incompressible flows, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, pp.44-476011, 2006. ,
DOI : 10.1016/j.cma.2005.10.010
Passerelles volumes finis ??? ??l??ments finis, Comptes Rendus de l'Acad??mie des Sciences - Series I - Mathematics, vol.328, issue.8, pp.711-716, 1999. ,
DOI : 10.1016/S0764-4442(99)80240-7
A Projection FEM for Variable Density Incompressible Flows, Journal of Computational Physics, vol.165, issue.1, pp.167-188, 2000. ,
DOI : 10.1006/jcph.2000.6609
Finite element methods for Navier-Stokes equations Theory and algorithms, of Springer Series in Computational Mathematics, 1986. ,
Time-dependent viscous incompressible Navier-Stokes equations: The finite difference Galerkin formulation and streamfunction algorithms, Journal of Computational Physics, vol.84, issue.1, pp.207-241, 1989. ,
DOI : 10.1016/0021-9991(89)90188-5
Modelling and simulation of fires in vehicle tunnels, International Journal for Numerical Methods in Fluids, vol.44, issue.3, pp.277-296, 2004. ,
DOI : 10.1002/fld.638
Stabilization of Galerkin approximations of transport equations by subgrid modeling, M2AN), pp.1293-1316, 1999. ,
DOI : 10.1051/m2an:1999145
Solvability of Nonstationary Problems for Nonhomogeneous Incompressible Fluids and the Convergence with Vanishing Viscosity, Tokyo Journal of Mathematics, vol.22, issue.1, pp.17-42, 1999. ,
DOI : 10.3836/tjm/1270041610
Accurate, stable and efficient Navier-Stokes solvers based on explicit treatment of the pressure term Sur le mouvement d'un liquide visqueux emplissant l'espace, J. Comput. Phys. Acta Math, vol.199, issue.63, pp.221-259193, 1934. ,
Finite volume methods for hyperbolic problems. Cambridge Texts in Applied Mathematics, 2002. ,
Mathematical topics in fluid mechanics Incompressible models, of Oxford Lecture Series in Mathematics and its Applications, 1996. ,
Mathematical topics in fluid mechanics Compressible models, of Oxford Lecture Series in Mathematics and its Applications, 1998. ,
Convergence of the finite volume method for scalar conservation laws with discontinuous flux function, Modél. Math. Anal. Numér, issue.M2AN ,
Error estimate for finite volume scheme, Numerische Mathematik, vol.94, issue.3, pp.129-155, 2007. ,
DOI : 10.1007/s00211-006-0053-y
URL : https://hal.archives-ouvertes.fr/hal-00008660
On combining finite element methods and finite volume methods in computational fluid dynamics, Progress in analysis, pp.1205-1213, 2001. ,
Footbridge between finite volumes and finite elements with applications to CFD, International Journal for Numerical Methods in Fluids, vol.27, issue.8, pp.951-986181, 2001. ,
DOI : 10.1002/fld.199
Extension of Finite Volume Compressible Flow Solvers to Multi-dimensional, Variable Density Zero Mach Number Flows, Journal of Computational Physics, vol.155, issue.2, pp.248-286, 1999. ,
DOI : 10.1006/jcph.1999.6327
Artificial compressibility, characteristics-based schemes for variable density, incompressible, multi-species flows. I. Derivation of different formulations and constant density limit, J. Comput. Phys, vol.210, issue.2, pp.584-607, 2005. ,
Artificial compressibility, characteristics-based schemes for variable-density, incompressible, multispecies flows: Part II. Multigrid implementation and numerical tests, Journal of Computational Physics, vol.210, issue.2, pp.608-631, 2005. ,
DOI : 10.1016/j.jcp.2005.05.002
Non-conservative and conservative formulations of characteristics-based numerical reconstructions for incompressible flows, International Journal for Numerical Methods in Engineering, vol.86, issue.9, pp.1466-1482, 2006. ,
DOI : 10.1002/nme.1606
Unsteady solution of incompressible Navier-Stokes equations, Journal of Computational Physics, vol.79, issue.1, pp.113-134, 1988. ,
DOI : 10.1016/0021-9991(88)90007-1
On the construction and comparison of difference schemes, SIAM J. Numer. Anal, vol.5, pp.506-517, 1968. ,
Une méthode d'approximation de la solution deséquationsdeséquations de Navier-Stokes, Bull. Soc. Math. France, vol.98, pp.115-152, 1968. ,
Navier Stokes Equations: Theory and Numerical Analysis, Journal of Applied Mechanics, vol.45, issue.2, 2001. ,
DOI : 10.1115/1.3424338
Numerical simulations of the Rayleigh-Taylor instability, J. Comput. Phys, vol.75, pp.235-282, 1988. ,
Radiation models for thermal flows at low Mach number, J. Comput. Phys, vol.215, issue.2, pp.506-525, 2006. ,
Efficient Solvers for Incompressible Flow Problems, Lect. Notes in Comput. Sc. and Eng, 1999. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, Journal of Computational Physics, vol.32, issue.1, pp.101-136, 1979. ,
DOI : 10.1016/0021-9991(79)90145-1
On the Relation Between the Upwind-Differencing Schemes of Godunov, Engquist???Osher and Roe, SIAM Journal on Scientific and Statistical Computing, vol.5, issue.1, pp.1-20, 1984. ,
DOI : 10.1137/0905001
Implicit Method for the Computation of Unsteady Flows on Unstructured Grids, Journal of Computational Physics, vol.127, issue.2, pp.380-397, 1996. ,
DOI : 10.1006/jcph.1996.0182
