Vibration-based structural damage identiication, Philosophical Transactions of the Royal Society: Mathematical , Physical and Engineering Sciences, pp.359-131, 1778. ,
Model-Aided Diagnosis of Mechanical Systems: Fundamentals, Detection, 1997. ,
DOI : 10.1007/978-3-642-60413-3
Recent d e v elopments in vibration-based structural health monitoring, Proceedings of the 5th International Workshop on Structural Health Monitoring, pp.42-60, 2005. ,
Vibration-based damage detection in civil engineering: excitation sources and temperature effects, Smart Materials and Structures, vol.10, issue.3, pp.518-527, 2001. ,
DOI : 10.1088/0964-1726/10/3/314
Structural causes of temperature aaected modal data of civil structures obtained by long time monitoring, Proceedings of the 18th International Modal Analysis Conference, 2000. ,
Structural health monitoring under variable environmental or operational conditions, Proceedings of the 2nd European Workshop on Structural Health Monitoring, 2004. ,
DOI : 10.1007/978-3-7091-0399-9_4
Subspace-based fault detection algorithms for vibration monitoring, Automatica, vol.36, issue.1, pp.101-109, 2000. ,
DOI : 10.1016/S0005-1098(99)00093-X
APPLICATION OF A SUBSPACE-BASED FAULT DETECTION METHOD TO INDUSTRIAL STRUCTURES, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.823-838, 1999. ,
DOI : 10.1006/mssp.1999.1247
Output-Only Subspace-Based Damage Detection - Application to a Reticular Structure, Structural Health Monitoring, vol.2, issue.2, pp.161-168, 2003. ,
DOI : 10.1177/1475921703002002008
Structural Dynamics Toolbox. User's Guide Version 5, 2006. ,
Handling the temperature eect in SHM: combining a subspace-based statistical test and a temperature-adjusted null space, Proceedings of the 3rd European Workshop on Structural Health Monitoring, pp.759-766, 2006. ,
Natural frequencies of beams under compressive axial loads 49{65. List of Figures 1 Bridge deck -Top: The model with the sensors location. Bottom: The damaged area, Journal of Sound and Vibration, vol.126, issue.1, p.16, 1988. ,
Linear thermal eld Bottom: Induced axial stress, p.17 ,
