Reports
Efficient schemes for total variation minimization under constraints in image processing
Pierre Weiss 1 Gilles Aubert 2 Laure Blanc-Féraud 1
1 ARIANA - Inverse problems in earth monitoring
CRISAM - Inria Sophia Antipolis - Méditerranée , Laboratoire I3S - SIS - Signal, Images et Systèmes
Abstract : This paper presents new algorithms to minimize total variation and more generally $l^1$-norms under a general convex constraint. The algorithms are based on a recent advance in convex optimization proposed by Yurii Nesterov. Depending on the regularity of the data fidelity term, we solve either a primal problem, either a dual problem. First we show that standard first order schemes allow to get solutions of precision $\epsilon$ in $O(\frac{1}{\epsilon^2})$ iterations at worst. For a general convex constraint, we propose a scheme that allows to obtain a solution of precision $\epsilon$ in $O(\frac{1}{\epsilon})$ iterations. For a strongly convex constraint, we solve a dual problem with a scheme that requires $O(\frac{1}{\sqrt{\epsilon}})$ iterations to get a solution of precision $\epsilon$. Thus, depending on the regularity of the data term, we gain from one to two orders of magnitude in the convergence rates with respect to standard schemes. Finally we perform some numerical experiments which confirm the theoretical results on various problems.
Complete list of metadata
Cited literature [48 references]  Display  Hide  Download
https://hal.inria.fr/inria-00166096
Contributor : Pierre Weiss Connect in order to contact the contributor
Submitted on : Friday, March 7, 2008 - 5:40:30 PM
Last modification on : Thursday, August 4, 2022 - 5:05:31 PM
Long-term archiving on: : Friday, November 25, 2016 - 9:36:56 PM
RR-6260.pdf
Identifiers
  • HAL Id : inria-00166096, version 3
Citation
Pierre Weiss, Gilles Aubert, Laure Blanc-Féraud. Efficient schemes for total variation minimization under constraints in image processing. [Research Report] RR-6260, INRIA. 2007, pp.36. ⟨inria-00166096v3⟩
Share
Metrics
Record views
682
Files downloads
989
