Building a Virtual Globus Grid in a Reconfigurable Environment - A case study: Grid5000
With the continuous evolution of distributed computing grids and with the perpetuous development of the available computing resources and protocols, there is a \textit{sine qua non} requirement to pass beyond the physical design of the grids. A viable solution is offered by virtual grids, having the advantage of flexible mapping and adaptation to live in-place resources. A software image is proposed, built with the use of the Globus Toolkit, the herein document describing the construction and configuratin phases as well as the deployment protocol in a live grid - Grid5000.
