HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Scheduling messages with offsets in automotive networks - a major performance boost
Nicolas Navet 1
1 TRIO - Real time and interoperability
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : With the always increasing use of electronics, best using the bandwidth is of primary importance in automotive networks. An element of solution is to schedule messages with offsets, which leads to a desynchronization of the streams of messages that is very beneficial in terms of worst-case response times because the traffic is distributed more uniformly over time. Two problems, difficult from an algorithmic point of view, are to be solved: choosing the offsets and computing the worst-case response times. The talk will discuss solutions in the case of Controller Area Network, which is by far the most widely used automotive networks. Experiments demonstrate that offsets actually provide a major performance boost in terms of worst-case response time and may lengthen the lifespan of CAN, despite the availability of FlexRay.
Complete list of metadata
https://hal.inria.fr/inria-00168531
Contributor : Nicolas Navet Connect in order to contact the contributor
Submitted on : Tuesday, August 28, 2007 - 10:31:54 PM
Last modification on : Friday, February 4, 2022 - 3:31:49 AM
Identifiers
  • HAL Id : inria-00168531, version 1
Collections
Citation
Nicolas Navet. Scheduling messages with offsets in automotive networks - a major performance boost. Seminar of the Department of Computer Science of Université Libre de Bruxelles (ULB), May 2007, Bruxelles, Belgium. ⟨inria-00168531⟩
Share
Metrics
Record views
65
