HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Shock Structure in a Two-phase Isothermal Euler Model
Hervé Guillard 1 Vincent Perrier 2
1 SMASH - Simulation, modeling and analysis of heterogeneous systems
CRISAM - Inria Sophia Antipolis - Méditerranée , Université de Provence - Aix-Marseille 1
Abstract : We have performed a traveling wave analysis of a two phase isothermal Euler model to exhibit the inner structure of shock waves in two-phase flows. In the model studied in this work, the dissipative regularizing term is not of viscous type but instead comes from relaxation phenomena toward equilibrium between the phases. This gives an unusual structure to the diffusion tensor where dissipative terms appear only in the mass conservation equations. We show that this implies that the mass fractions are not constant inside the shock although the Rankine-Hugoniot relations give a zero jump of the mass fraction through the discontinuities. We also show that there exists a critical speed for the traveling waves above which no C 1 solutions exist. Nevertheless for this case, it is possible to construct traveling solutions involving single phase shocks.
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00168787
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Friday, August 31, 2007 - 9:27:11 AM
Last modification on : Friday, February 4, 2022 - 3:22:52 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 1:32:17 PM
RR-6274.pdf
Identifiers
  • HAL Id : inria-00168787, version 2
Citation
Hervé Guillard, Vincent Perrier. Shock Structure in a Two-phase Isothermal Euler Model. [Research Report] RR-6274, INRIA. 2007, pp.23. ⟨inria-00168787v2⟩
Share
Metrics
Record views
422
Files downloads
158
