Analysis of a quadratic programming decomposition algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We analyze a decomposition algorithm for minimizing a quadratic objective function, separable in x1 and x2, subject to the constraint that x1 and x2 are orthogonal vectors on the unit sphere. Our algorithm consists of a local step where we minimize the objective function in either variable separately, while enforcing the constraints, followed by a global step where we minimize over a subspace generated by solutions to the local subproblems. We establish a local convergence result when the global minimizers nondegenerate. Our analysis employs necessary and sufficient conditions and continuity properties for a global optimum of a quadratic objective function subject to a sphere constraint and a linear constraint. The analysis is connected with a new domain decomposition algorithm for electronic structure calculations.
paper_INRIA.pdf (541.76 Ko) Télécharger le fichier
inria-00169080 , version 1 (31-08-2007)
inria-00169080 , version 2 (13-09-2007)
inria-00169080 , version 3 (14-09-2007)
inria-00169080 , version 4 (01-06-2009)
inria-00169080 , version 5 (02-06-2009)
  • HAL Id : inria-00169080 , version 4
William Hager, Guy Bencteux, Eric Cancès, Claude Le Bris. Analysis of a quadratic programming decomposition algorithm. [Research Report] RR-6288, 2007. ⟨inria-00169080v4⟩
280 Consultations
494 Téléchargements
