Column Generation based Solution for a Tactical Inventory Routing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Inventory routing problems combine the optimization of product deliveries (or pickups) with inventory control at customer sites. Our application concerns the planning of single product pickups over time; each site accumulates stock at a deterministic rate; the stock is emptied on each visit. At the tactical planning stage considered here, our objective is to minimize a surrogate measure of routing cost while achieving some form of regional clustering by partitioning the sites between the vehicles. The fleet size is given but can potentially be reduced. Planning consists in assigning customers to vehicles in each time period, but the routing, i.e., the actual sequence in which vehicles visit customers, is considered as an ``operational'' decision. The planning is due to be repeated over the time horizon with constrained periodicity. We develop a truncated branch-and-price-and-cut algorithm combined with rounding and local search heuristics that yields both primal solutions and dual bounds. On a large scale test problem coming from industry, we obtain a solution within 6.25% deviation from the optimal. A rough comparison between an operational routing resulting from our tactical solution and the industrial practice shows a 10% decrease in number of vehicles as well as in travel distance. The key to the success of the approach is the use of a state-space relaxation technique in formulating the master program to avoid the symmetry in time.
techRepR2.pdf (350.96 Ko) Télécharger le fichier
test0.mixte (3.71 Ko) Télécharger le fichier
test0.rural (3.71 Ko) Télécharger le fichier
test0.urbain (3.71 Ko) Télécharger le fichier
test1.mixte (3.71 Ko) Télécharger le fichier
test1.rural (3.71 Ko) Télécharger le fichier
test2.rural (3.71 Ko) Télécharger le fichier
test3.mixte (3.72 Ko) Télécharger le fichier
test3.urbain (3.72 Ko) Télécharger le fichier
test6.mixte (3.71 Ko) Télécharger le fichier
test9.rural (3.71 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00169311 , version 1 (03-09-2007)
inria-00169311 , version 2 (03-09-2007)
inria-00169311 , version 3 (14-11-2008)
inria-00169311 , version 4 (15-11-2008)
  • HAL Id : inria-00169311 , version 3
Sophie Michel, François Vanderbeck. Column Generation based Solution for a Tactical Inventory Routing Problem. [Research Report] 2008. ⟨inria-00169311v3⟩
377 Consultations
360 Téléchargements
