IPv4 to IPv6 Transition Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
The transition from IPv4 to IPv6 will be a major issue in the next few years, as IPv6 deployment began. In this report, we present the outcome of a study on this subject. It is composed of an initial addressing algorithm, the tool implementing this algorithm, and a routing configuration generator.
RT-0344.pdf (634.26 Ko) Télécharger le fichier
inria-00169993 , version 1 (06-09-2007)
inria-00169993 , version 2 (31-10-2007)
inria-00169993 , version 3 (02-11-2007)
  • HAL Id : inria-00169993 , version 3
Frédéric Beck, Olivier Festor, Isabelle Chrisment. IPv4 to IPv6 Transition Engine. [Technical Report] RT-0344, INRIA. 2007, pp.38. ⟨inria-00169993v3⟩
158 Consultations
175 Téléchargements
