Compiler-based approach for exploiting scratch-pad in presence of irregular array access The Next Generation of Intel IXP Network Processors, DATE, 2002. ,
Influence of array allocation mechanisms on memory system energy, Proceedings 15th International Parallel and Distributed Processing Symposium. IPDPS 2001, p.3, 2001. ,
DOI : 10.1109/IPDPS.2001.924930
An optimal memory allocation scheme for scratch-pad-based embedded systems, ACM Transactions on Embedded Computing Systems, vol.1, issue.1, pp.6-26, 2002. ,
DOI : 10.1145/581888.581891
Scratchpad memory, Proceedings of the tenth international symposium on Hardware/software codesign , CODES '02, pp.73-78, 2002. ,
DOI : 10.1145/774789.774805
System-level power optimization, Proceedings of the 1999 international symposium on Low power electronics and design , ISLPED '99, pp.288-293, 1999. ,
DOI : 10.1145/313817.313957
System-level power optimization, Proceedings of the 1999 international symposium on Low power electronics and design , ISLPED '99, pp.74-85, 2000. ,
Increasing energy efficiency of embedded systems by application-specific memory hierarchy generation, IEEE Design & Test of Computers, vol.17, issue.2, pp.74-85, 2000. ,
DOI : 10.1109/54.844336
Heap data allocation to scratch-pad memory in embedded systems, ACM Transactions on Design Automation of Electronic Systems, vol.5, issue.2, pp.115-192, 2005. ,
Scratchpad memory management for portable systems with a memory management unit, Proceedings of the 6th ACM & IEEE International conference on Embedded software , EMSOFT '06, 2006. ,
DOI : 10.1145/1176887.1176933
Power aware computing, 2002. ,
DOI : 10.1007/978-1-4757-6217-4
EMBARC: An Efficient Memory Bank Assignment Algorithm for Retargetable Compilers, ACM SIG- PLAN/SIGBED conference on Languages, compilers, and tools for embedded systems, pp.182-191, 2004. ,
Dynamic management of scratch-pad memory space, Proceedings of the 38th conference on Design automation , DAC '01, 2001. ,
DOI : 10.1145/378239.379049
Compiler-guided leakage optimization for banked scratch-pad memories, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.13, issue.10, pp.1136-1146, 2005. ,
DOI : 10.1109/TVLSI.2005.859478
Memory allocation for embedded systems with a compile-time-unknown scratch-pad size Efficient utilization of scratch-pad memory in embedded processor applications An integrated hardware/software approach for run-time scratchpad management, CASES, 2005. [Panda et DATE DAC, pp.238-243, 1997. ,
Reducing energy consumption by dynamic copying of instructions onto onchip memory, Proceedings of the 15th international symposium on System Synthesis , ISSS '02, 2002. ,
DOI : 10.1145/581199.581247
Assigning program and data objects to scratchpad for energy reduction Compiler-decided dynamic memory allocation for scratch-pad based embedded systems An integrated scratch-pad allocator for affine and non-affine code Dynamic allocation for scratch-pad memory using compile-time decisions, DATE DATE, pp.409-276, 2002. ,
Data Partitioning for Maximal Scratchpad Usage, ASPDAC, 2003. ,
DOI : 10.1145/1119772.1119788
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.2876
Dynamic overlay of scratchpad memory for energy minimization, Proceedings of the 2nd IEEE/ACM/IFIP international conference on Hardware/software codesign and system synthesis , CODES+ISSS '04, 2004. ,
DOI : 10.1145/1016720.1016748
Memory and compiler optimizations for low-power and energy, ICOOOLPS, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00104146
