Measuring the robustness of a resource allocation, IEEE Transactions on Parallel and Distributed Systems, vol.15, issue.7, pp.630-641, 2004. ,
DOI : 10.1109/TPDS.2004.24
Representing Task and Machine Heterogeneities for Heterogeneous Computing Systems, Tamkang Journal of Science and Engineering, vol.3, issue.3, pp.195-207, 2000. ,
Robust scheduling of metaprograms, Journal of Scheduling, vol.10, issue.5, pp.395-412, 2002. ,
DOI : 10.1002/jos.115
Parallel Gaussian elimination on an MIMD computer, Parallel Computing, vol.6, issue.3, pp.275-296, 1988. ,
DOI : 10.1016/0167-8191(88)90070-1
Slack-based Techniques for Robust Schedules, Proceedings of the Sixth European Conference on Planning (ECP-2001), 2001. ,
Bounding the Project Completion Time Distribution in PERT Networks, Operations Research, vol.33, issue.4, pp.862-881, 1985. ,
DOI : 10.1287/opre.33.4.862
A new metric for robustness with application to job scheduling, HPDC-14. Proceedings. 14th IEEE International Symposium on High Performance Distributed Computing, 2005., pp.135-143, 2005. ,
DOI : 10.1109/HPDC.2005.1520948
Computational complexity of PERT problems, Networks, vol.8, issue.2, pp.139-147, 1998. ,
DOI : 10.1002/net.3230180206
Estimating the Execution Time Distribution for a Task Graph in a Heterogeneous Computing System, 6th IEEE Heterogeneous Computing Workshop (HCW'97), pp.172-184, 1997. ,
A Computational Study on Bounding the Makespan Distribution in Stochastic Project Networks, Annals of Operations Research, vol.102, pp.1-449, 2001. ,
A dynamic matching and scheduling algorithm for heterogeneous computing systems, Proceedings Seventh Heterogeneous Computing Workshop (HCW'98), pp.57-69, 1998. ,
DOI : 10.1109/HCW.1998.666545
A static scheduling heuristic for heterogeneous processors, Proceedings of the Second International Euro-Par Conference on Parallel Processing-Volume II, pp.573-577, 1996. ,
DOI : 10.1007/BFb0024750
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.37.6178
A hybrid heuristic for DAG scheduling on heterogeneous systems, 18th International Parallel and Distributed Processing Symposium, 2004. Proceedings., 2004. ,
DOI : 10.1109/IPDPS.2004.1303065
A Stochastic Approach to Measuring the Robustness of Resource Allocations in Distributed Systems, 2006 International Conference on Parallel Processing (ICPP'06), pp.459-470, 2006. ,
DOI : 10.1109/ICPP.2006.14
Robust task scheduling in non-deterministic heterogeneous computing systems, 2006 IEEE International Conference on Cluster Computing, pp.1-10, 2006. ,
DOI : 10.1109/CLUSTR.2006.311868
A compile-time scheduling heuristic for interconnection-constrained heterogeneous processor architectures, IEEE Transactions on Parallel and Distributed Systems, vol.4, issue.2, pp.175-187, 1993. ,
DOI : 10.1109/71.207593
Task scheduling algorithms for heterogeneous processors, Proceedings. Eighth Heterogeneous Computing Workshop (HCW'99), pp.3-14, 1999. ,
DOI : 10.1109/HCW.1999.765092
