Recent Advances in Solving the Protein Threading Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The fold recognition methods are promissing tools for capturing the structure of a protein by its amino acid residues sequence but their use is still restricted by the needs of huge computational resources and suitable efficient algorithms as well. In the recent version of FROST (Fold Recognition Oriented Search Tool) package the most efficient algorithm for solving the Protein Threading Problem (PTP) is implemented due to the strong collaboration between the SYMBIOSE group in IRISA and MIG in Jouy-en-Josas. In this paper, we present the diverse components of FROST, emphasizing on the recent advances in formulating and solving new versions of the PTP and on the way of solving on a computer cluster a million of instances in a easonable time.
PI-1856.pdf (897.51 Ko) Télécharger le fichier
inria-00170619 , version 1 (10-09-2007)
  • HAL Id : inria-00170619 , version 1
Rumen Andonov, Guillaume Collet, Jean-François Gibrat, Antoine Marin, Vincent Poirriez, et al.. Recent Advances in Solving the Protein Threading Problem. [Research Report] PI 1856, 2007, pp.38. ⟨inria-00170619⟩
413 Consultations
184 Téléchargements
