Abstract : Renumbering is an integral part of the IPv6 protocol. This service is enabled by the Neighbor Discovery protocol. While offering several advantages, this protocol represents a serious security threat to the integrity of the network. The renumbering procedure can indeed create vulnerabilities in the network security by deploying a parallel routing infrastructure for a new prefix. This document contains a description of a complete monitoring framework architecture for monitoring the whole procedure and ensure it is done safely. This study was supported by CISCO Systems as part of the CISCO Applied Research and Developpement program.
