Bandwidth selection for kernel estimation in mixed multi-dimensional spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aurelie Bugeau
Patrick Pérez
  • Fonction : Auteur
  • PersonId : 1022281
Kernel estimation techniques, such as mean shift, suffer from one major drawback: the kernel bandwidth selection. The bandwidth can be fixed for all the data set or can vary at each points. Automatic bandwidth selection becomes a real challenge in case of multidimensional heterogeneous features. This paper presents a solution to this problem. It is an extension of \cite{Comaniciu03a} which was based on the fundamental property of normal distributions regarding the bias of the normalized density gradient. The selection is done iteratively for each type of features, by looking for the stability of local bandwidth estimates across a predefined range of bandwidths. A pseudo balloon mean shift filtering and partitioning are introduced. The validity of the method is demonstrated in the context of color image segmentation based on a 5-dimensional space.
RR-6286.pdf (374.64 Ko) Télécharger le fichier
inria-00171686 , version 1 (12-09-2007)
inria-00171686 , version 2 (14-09-2007)
  • HAL Id : inria-00171686 , version 2
  • ARXIV : 0709.1920
Aurelie Bugeau, Patrick Pérez. Bandwidth selection for kernel estimation in mixed multi-dimensional spaces. [Research Report] RR-6286, INRIA. 2007. ⟨inria-00171686v2⟩
167 Consultations
399 Téléchargements
