HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A model for checking consistency in access control policies for network management
Radu State 1 Vincent Cridlig 1 Olivier Festor 1
1 MADYNES - Management of dynamic networks and services
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper addresses the consistency of initially heterogeneous access control policies in the network management area. It addresses the well-know network management frameworks like SNMP (v3), CLI, Netconf and the lesser known TR-069 proposed in the framework of ADSL operators. For each of these, a formal definition of the access control model is proposed as well as the conversion towards a unified Role-Based Access Control model. Next, we show how to compare roles and permissions between the generated access control policies and to answer to questions like: which policy is more permissive, what are the common privileges between a set of roles ?
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00172054
Contributor : Radu State Connect in order to contact the contributor
Submitted on : Thursday, September 13, 2007 - 11:41:29 PM
Last modification on : Friday, February 26, 2021 - 3:28:04 PM
Identifiers
  • HAL Id : inria-00172054, version 1
Collections
Citation
Radu State, Vincent Cridlig, Olivier Festor. A model for checking consistency in access control policies for network management. 10th IFIP/IEEE International Symposium on Integrated Management (IM 2007), May 2007, Munich, Germany. ⟨inria-00172054⟩
Share
Metrics
Record views
65
