Model Transformations from a Data Parallel Formalism towards Synchronous Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The increasing complexity of embedded system designs calls for high-level specification formalisms and for automated transformations towards lower-level descriptions. In this report, a metamodel and a transformation chain are defined from a high-level modeling framework, Gaspard, for data-parallel systems towards a formalism of synchronous equations. These equations are translated in synchronous data-flow languages, such as Lustre, Lucid synchrone and Signal, which provide designers with formal techniques and tools for validation. In order to benefit from the methodological advantages of re-usability and platform-independence, a Model-Driven Engineering approach is applied.
RR-6291.pdf (707.56 Ko) Télécharger le fichier
inria-00172302 , version 1 (14-09-2007)
inria-00172302 , version 2 (17-09-2007)
  • HAL Id : inria-00172302 , version 2
Huafeng Yu, Abdoulaye Gamatié, Eric Rutten, Jean-Luc Dekeyser. Model Transformations from a Data Parallel Formalism towards Synchronous Languages. [Research Report] RR-6291, INRIA. 2007. ⟨inria-00172302v2⟩
204 Consultations
334 Téléchargements
