A computational fluid mechanics solution to the Monge-Kantorovich mass transfer problem, Numerische Mathematik, vol.84, issue.3, pp.375-393, 2000. ,
DOI : 10.1007/s002110050002
Wall-function treatment in pdf methods for turbulent flows, Physics of Fluids, vol.9, issue.9, pp.2692-2703, 1997. ,
DOI : 10.1063/1.869381
A description of the fifth-generation penn state/ncar mesoscale model (mm5). NCAR Technical Note, p.122, 1995. ,
Terrain and land use for the fifth-generation penn state/ncar mesoscale modeling system (mm5). NCAR Technical Note, 1994. ,
Existence and uniqueness of monotone measure-preserving maps. Duke Math, J, vol.80, issue.2, pp.309-323, 1995. ,
Lagrangian PDF Methods for Turbulent Flows, Annual Review of Fluid Mechanics, vol.26, issue.1, pp.23-63, 1994. ,
DOI : 10.1146/annurev.fl.26.010194.000323
Probabilistic numerical methods for partial differential equations: Elements of analysis ,
DOI : 10.1080/07362999008809220
Topics in optimal transportation, Graduate Studies in Mathematics, vol.58, 2003. ,
DOI : 10.1090/gsm/058
