Near real-time analysis of the mesoscale circulation during the POMME experiment, Deep-sea Res. I 52, pp.1345-73, 2005. ,
A strategy for operational implementation of 4D-Var, using an incremental approach, Quarterly Journal of the Royal Meteorological Society, vol.45, issue.519, pp.1367-87, 1994. ,
DOI : 10.1002/qj.49712051912
4D-Var assimilation of Argo profiles applied to North Atlantic ocean climate monitoring, Giering R and Kaminski T 1998 Recipes for adjoint code construction, pp.437-74, 2004. ,
Lagrangian data assimilation for point vortex systems, Journal of Turbulence, vol.75, p.53, 2002. ,
DOI : 10.1016/S0377-0265(97)00016-X
Continuous data assimilation of drifting buoy trajectory into an equatorial Pacific Ocean model, Journal of Marine Systems, vol.6, issue.1-2, pp.159-78, 1995. ,
DOI : 10.1016/0924-7963(94)00022-4
A method for assimilation of Lagrangian data, Mon.Weather Rev, pp.2247-60, 2003. ,
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
1 ocean general circulation model reference manual, Notes du pole de Modelisation de l, 1998. ,
Assimilation of simulated float data in Lagrangian coordinates, Ocean Model, pp.369-94, 2005. ,
Assimilation of drifter observations for the reconstruction of the Eulerian circulation field, Journal of Geophysical Research, vol.106, issue.3, p.3056, 2003. ,
DOI : 10.1029/2001JC001240
Variational assimilation of Lagrangian data in oceanography, Inverse Problems, vol.22, issue.1, pp.245-263, 2006. ,
DOI : 10.1088/0266-5611/22/1/014
URL : https://hal.archives-ouvertes.fr/inria-00173069
Assimilation of drifter observations in primitive equation models of midlatitude ocean circulation, Journal of Geophysical Research, vol.106, issue.4, p.3238, 2003. ,
DOI : 10.1029/2002JC001719
A method for assimilating Lagrangian data into a shallow-water equation ocean model, Mon. Weather Rev. at press Weaver A T and Courtier P 2001 Correlation modeling on the sphere using a generalized diffusion equation, Q, J. R. Meteorol. Soc, vol.127, pp.1815-1861, 2006. ,
Three-and four-dimensional variational assimilation with an ocean general circulation model of the tropical Pacific Ocean: I. Formulation, internal diagnostics and consistency checks, Mon. Weather Rev, pp.1360-78, 2003. ,
