Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Xse: quasi-random mutations for evolution strategies, Proceedings of Evolutionary Algorithms, 2005. ,
Dynamic Programming, 1957. ,
Dynamic Programming and Optimal Control, vols I and II, 1995. ,
What can we learn from no free lunch? a first attempt to characterize the concept of a searchable function, Proceedings of the Genetic and Evolutionary Computation Conference, pp.1219-1226, 2001. ,
Not all linear functions are equally difficult for the compact genetic algorithm, Proceedings of the 2005 conference on Genetic and evolutionary computation , GECCO '05, pp.679-686, 2005. ,
DOI : 10.1145/1068009.1068124
Introduction to Evolutionary Computing, 2003. ,
Open BEAGLE, Late breaking papers of the GECCO 2002, pp.161-168, 2002. ,
DOI : 10.1145/1138470.1138473
Resource-Aware Parameterizations of EDA, 2006 IEEE International Conference on Evolutionary Computation, 2006. ,
DOI : 10.1109/CEC.2006.1688620
URL : https://hal.archives-ouvertes.fr/inria-00112803
Genetic algorithms in search, optimization and machine learning, 1989. ,
Completely Derandomized Self-Adaptation in Evolution Strategies, Evolutionary Computation, vol.9, issue.2, 2003. ,
DOI : 10.1016/0004-3702(95)00124-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.7462
Bayes point machines, Journal of Machine Learning Research, vol.1, pp.245-279, 2001. ,
Adaptation in natural and artificial systems, 1975. ,
`` Direct Search'' Solution of Numerical and Statistical Problems, Journal of the ACM, vol.8, issue.2, pp.212-229, 1961. ,
DOI : 10.1145/321062.321069
Runtime analysis of a (mu+1)es for the sphere function, 2005. ,
Algorithm 178: direct search, Communications of the ACM, vol.6, issue.6, pp.313-314, 1963. ,
DOI : 10.1145/366604.366632
A Simplex Method for Function Minimization, The Computer Journal, vol.7, issue.4, pp.308-311, 1965. ,
DOI : 10.1093/comjnl/7.4.308
Robustness in combinatorial optimization and scheduling theory: An annotated bibliography. Optimization online, 2004. ,
Convergence rates of evolutionary algorithms for a class of convex objective functions, Control and Cybernetics, vol.26, issue.3, pp.375-390, 1997. ,
On the benefits of inoculation, an example in train scheduling, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.1761-1768, 2006. ,
DOI : 10.1145/1143997.1144283
URL : https://hal.archives-ouvertes.fr/inria-00116345
Problem definitions and evaluation criteria for the cec 2005 special session on realparameter optimization, 2005. ,
General Lower Bounds for Evolutionary Algorithms, 10 th International Conference on Parallel Problem Solving from Nature, 2006. ,
DOI : 10.1007/11844297_3
URL : https://hal.archives-ouvertes.fr/inria-00112820
On the Convergence of the Multidirectional Search Algorithm, SIAM Journal on Optimization, vol.1, issue.1, pp.123-145, 1991. ,
DOI : 10.1137/0801010
An informational approach to the global optimization of expensive-to-evaluate functions, Journal of Global Optimization, vol.10, issue.5 ,
DOI : 10.1007/s10898-008-9354-2
URL : https://hal.archives-ouvertes.fr/hal-00354262
Subthreshold-Seeking Behavior and Robust Local Search, Proceedings of GECCO, pp.282-293, 2004. ,
DOI : 10.1007/978-3-540-24855-2_25
No free lunch theorems for search, 1995. ,
Direct search methods: Once scorned, now respectable Numerical Analysis, Pitman Research Notes in Mathematics, pp.191-208, 1995. ,
L-BFGS-B: a limited memory FORTRAN code for solving bound constrained optimization problems, 1994. ,
