Generic Expression in B of the Influence/Reaction Model: Specifying and Verifying Situated Multi-Agent Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Simonin
Arnaud Lanoix
Samuel Colin
  • Fonction : Auteur
  • PersonId : 837524
Alexis Scheuer
  • Fonction : Auteur
  • PersonId : 830058
This paper addresses the formal specification and verification of situated multi-agent systems that can be formulated within the influence-reaction model as proposed in 1996 by Ferber & Muller. In this framework our objective is to prove the correctness of reactive multi-agent systems with respect to a certain formal specification or property, using formal methods. This is an important step to bring multi-agent systems to high quality standards as required for critical applications encountered in domains such as transport systems. A generic B writing of systems instantiating the influence reaction model is proposed, using patterns of specification. An illustration is then presented on the formal specification of a system operating electrical vehicles under precise automatic control at close spacings to form a platoon. The papers ends with considerations about further improvements of the framework, involving simulation and study of the properties of the system.
SimoninEtalRR07.pdf (1.3 Mo) Télécharger le fichier
inria-00173876 , version 1 (20-09-2007)
inria-00173876 , version 2 (26-09-2007)
  • HAL Id : inria-00173876 , version 2
Olivier Simonin, Arnaud Lanoix, Samuel Colin, Alexis Scheuer, François Charpillet. Generic Expression in B of the Influence/Reaction Model: Specifying and Verifying Situated Multi-Agent Systems. [Research Report] RR-6304, INRIA. 2007, pp.18. ⟨inria-00173876v2⟩
217 Consultations
307 Téléchargements
