Reports
On the Baer extension problem for multidimensional linear systems
Abstract : Within an algebraic analysis approach, the purpose of the paper is to constructively solve the following problem: given two fixed multidimensional linear systems $S_1$ and $S_2$, parametrize the multidimensional linear systems $S$ which contain $S_1$ as a subsystem and satisfy that $S/S_1$ is isomorphic to $S_2$. In order to study this problem, we use Baer's classical interpretation of the extension functor and give an explicit characterization and parametrization of the equivalence classes of multidimensional linear systems $S$ solving this problem. We then use these results to parametrize the equivalence classes of multidimensional linear systems $S$ which admit a fixed parametrizable subsystem $S_1$ and satisfy that $S/S_1$ is isomorphic to a fixed autonomous system $S_2$. We illustrate the main results by means of explicit examples of differential time-delay systems.
Document type :
Reports
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/inria-00175272
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Thursday, September 27, 2007 - 4:55:11 PM
Last modification on : Saturday, June 25, 2022 - 10:58:02 PM
Long-term archiving on: : Tuesday, September 21, 2010 - 1:18:09 PM
RR-6307.pdf
Identifiers
  • HAL Id : inria-00175272, version 2
Collections
Citation
Alban Quadrat, Daniel Robertz. On the Baer extension problem for multidimensional linear systems. [Research Report] RR-6307, INRIA. 2007, pp.43. ⟨inria-00175272v2⟩
Share
Metrics
Record views
105
Files downloads
97
