A new B-Spline based active contour approach
Sergio Nogueira 1, 2 Yassine Ruichek 2
1 MAIA - Autonomous intelligent machine
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : This paper proposes a new B-spline based active contour model for extracting areas of interest in an image. The model is governed by original external and internal energies. A self-adaptive technique for energies regulation is used to improve the convergence in terms of quality and rapidity. An adding control point procedure is introduced in order to improve the active contour convergence towards desired image characteristics. Real time applications like object tracking and/or detection could be considered using this new proposed active contour model.
Type de document :
Communication dans un congrès
IAPR Conference on Machine Vision Applications - MVA 2007, May 2007, Tokyo, Japan. 2007
Liste complète des métadonnées
https://hal.inria.fr/inria-00175743
Contributeur : Sergio Nogueira <>
Soumis le : lundi 1 octobre 2007 - 10:06:04
Dernière modification le : jeudi 11 janvier 2018 - 06:19:51
  • HAL Id : inria-00175743, version 1
Citation
Sergio Nogueira, Yassine Ruichek. A new B-Spline based active contour approach. IAPR Conference on Machine Vision Applications - MVA 2007, May 2007, Tokyo, Japan. 2007. 〈inria-00175743〉
Métriques
Consultations de la notice
189
