HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Java type unification with wild cards
Abstract : With the introduction of Java 5.0 the type system has been extended by parameterized types, type variables, type terms, and wildcards. As a result very complex types can arise. The term Vector is for example a correct type in Java 5.0. In this paper we present a type unification algorithm for Java 5.0 type terms. The algorithm unifies type terms, which are in subtype relationship. For this we define Java 5.0 type terms and its subtyping relation, formally. As Java 5.0 allows wildcards as instances of generic types, the subtyping ordering contains infinite chains. We show that the type unification is still finitary. We give a type unification algorithm, which calculates the finite set of general unifiers.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00175937
Contributor : Evelyne Contejean Connect in order to contact the contributor
Submitted on : Monday, October 1, 2007 - 5:24:00 PM
Last modification on : Monday, October 1, 2007 - 5:33:45 PM
Long-term archiving on: : Monday, September 24, 2012 - 1:01:00 PM
File
pluemicke.pdf
Identifiers
  • HAL Id : inria-00175937, version 1
Collections
Citation
Martin Pluemicke. Java type unification with wild cards. UNIF07, 2007, Paris, France. ⟨inria-00175937⟩
Share
Metrics
Record views
60
Files downloads
374
